MySQL Import Query
tpaolillo
MySQL Import Query
Post by tpaolillo »
Hi Im struggling with an option to import a CSV file into my MSQL database from within Robotask. Im using the latest 7.3.0.0964.
Attached is the CSV file im trying to import. Seems I cant use "INSERT INTO" with robotask because MySQL doesent support ADO or something.?.
Ive created a PHP file successfully with the following SQL code:
"$sql = "INSERT INTO simmons_pricechange (Location, SiteName, PanelID, PriceChangeTime, Grade, Name, OldPriceCash, NewPriceCash, CashPriceDifference, OldPriceCredit, NewPriceCredit, CreditPriceDifference, PriceChanged)
VALUES('" . implode("','",$row) . "')";"
However this is what I have in Robotask which fails because it doesent support INSERT INLINE:
"LOAD DATA INFILE 'C:\Support\SimmonsPrices\negw_dpcr_5006__20180722_204073114.csv'
INTO TABLE simmons_pricechange
FIELDS TERMINATED BY ','
ENCLOSED BY '"'
LINES TERMINATED BY '\n'
IGNORE 1 ROWS"
Can someone help me write a way to read from the CSV file and import it into my MySQL database? Can it be done?
Thanks in advance.
Tony
negw_dpcr_5006__20180722_204073114.zip
(6.27 KiB) Downloaded 1277 times
Re: MySQL Import Query
RoboTask uses ADO/ODBC interface to connect to any database.
So, this have some restrictions of SQL extensions of some databases. But it supports ANSI SQL completely.
You have to process CSV file line-by-line in the loop and add records sequentially
Look at my example:
CatID=INTEGER|179181099
ExternalName=STRING|"Task106"
ID=INTEGER|464676392
Name=STRING|"CSV to database"
Name=STRING|"Set variable ""CSVFILE"" with value ""D:\systemp\Downloads\negw_dpcr_5006__20180722_204073114.csv"""
varname=STRING|"CSVFILE"
varvalue=STRING|"D:\systemp\Downloads\negw_dpcr_5006__20180722_204073114.csv"
Name=STRING|"Set variable ""FIRST"" with value ""false"""
varname=STRING|"FIRST"
varvalue=STRING|"false"
Name=STRING|"Set variable ""FIRST"" with value ""true"""
varvalue=STRING|"true"
Name=STRING|"Text Loop"
destvar=STRING|"LINE"
file=STRING|"{CSVFile}"
linecount=STRING|"0"
sourcetext=STRING|"0"
Name=STRING|"//skip first line"
comment=STRING|"skip first line"
operator=STRING|"1"
value1=STRING|"{first}"
colon=STRING|"0"
comma=STRING|"1"
other=STRING|"0"
quote=STRING|"0"
semocolon=STRING|"0"
space=STRING|"0"
spaceasone=STRING|"0"
string=STRING|"{Line}"
tab=STRING|"0"
variable=STRING|"Line"
Enabled=INTEGER|0
Name=STRING|"Show ""{Line}"""
msg0=STRING|"{Line}"
msg1=STRING|"{Line(0)}"
msg10=STRING|"{Line(9)}"
msg11=STRING|"{Line(10)}"
msg12=STRING|"{Line(11)}"
msg13=STRING|"{Line(12)}"
msg2=STRING|"{Line(1)}"
msg3=STRING|"{Line(2)}"
msg4=STRING|"{Line(3)}"
msg5=STRING|"{Line(4)}"
msg6=STRING|"{Line(5)}"
msg7=STRING|"{Line(6)}"
msg8=STRING|"{Line(7)}"
msg9=STRING|"{Line(8)}"
msgcount=STRING|"14"
ActionID=STRING|"A_EXECSQL"
Name=STRING|"SQL Query"
assignvar=STRING|"0"
connectionstring=STRING|"Provider=MSDASQL.1;Persist Security Info=False;Data Source=mytest"
override=STRING|"0"
paramcount=STRING|"13"
password=STRING|"2133621135211341985520625"
pname0=STRING|"par0"
pname1=STRING|"par1"
pname10=STRING|"par10"
pname11=STRING|"par11"
pname12=STRING|"par12"
pname2=STRING|"par2"
pname3=STRING|"par3"
pname4=STRING|"par4"
pname5=STRING|"par5"
pname6=STRING|"par6"
pname7=STRING|"par7"
pname8=STRING|"par8"
pname9=STRING|"par9"
ptype0=STRING|"0"
ptype1=STRING|"0"
ptype10=STRING|"0"
ptype11=STRING|"0"
ptype12=STRING|"0"
ptype2=STRING|"0"
ptype3=STRING|"0"
ptype4=STRING|"0"
ptype5=STRING|"0"
ptype6=STRING|"0"
ptype7=STRING|"0"
ptype8=STRING|"0"
ptype9=STRING|"0"
pvalue0=STRING|"{line(0)}"
pvalue1=STRING|"{line(1)}"
pvalue10=STRING|"{line(10)}"
pvalue11=STRING|"{line(11)}"
pvalue12=STRING|"{line(12)}"
pvalue2=STRING|"{line(2)}"
pvalue3=STRING|"{line(3)}"
pvalue4=STRING|"{line(4)}"
pvalue5=STRING|"{line(5)}"
pvalue6=STRING|"{line(6)}"
pvalue7=STRING|"{line(7)}"
pvalue8=STRING|"{line(8)}"
pvalue9=STRING|"{line(9)}"
sql=STRING|"""INSERT INTO simmons_pricechange "",""(Location, SiteName, PanelID, "",""PriceChangeTime, Grade, Name, "",""OldPriceCash, NewPriceCash, CashPriceDifference, "",""OldPriceCredit, NewPriceCredit, CreditPriceDifference, PriceChanged)"",VALUES,""( :par0, :par1, :par2,"",""  :par3, :par4, :par5,"",""  :par6, :par7, :par8,"",""  :par9, :par10, :par11, :par12 )"""
timeout=STRING|"60"
Of course you have to change Connection string in SQL Query action
