Rename Files
dondada
Rename Files
Post by dondada »
All I'm trying to do is rename several existing files (which could number in the hundreds) to my selected filenames. I generate the files to rename using "Search for Files" and writing it to a text file. But for some reason it isn't working. See my task below with just 2 files for brevity. Thanks for the help.
;* RoboTask Task file *
;* Do not edit!       *
CatID=INTEGER|385352816
ExternalName=STRING|"Task18"
ID=INTEGER|837599829
Name=STRING|"Rename Files"
Name=STRING|"Text Loop"
destvar=STRING|"{CURRENTFILENAME}"
file=STRING|"C:\list"
line0=STRING|"G:\025837611.tif"
line1=STRING|"G:\02583768.tif"
linecount=STRING|"2"
sourcetext=STRING|"1"
destvar=STRING|"NEWFILENAME"
line0=STRING|"G:\113.tif"
line1=STRING|"G:\114.tif"
Name=STRING|"Rename File"
file0=STRING|"{CURRENTFILENAME}"
mask=STRING|"{NEWFILENAME}"
subdirs=STRING|"0"
Rename Files
It's incorrect method, because second loop will execute for each file from first loop. Each line of your list must contain old and new filenames. See task below.
In "search for files" action use "Insert text after" parameter.
Also you can generate newfilename directly. I can write an example, if needed.
;* Do not edit!       *
CatID=INTEGER|565106205
ExternalName=STRING|"Task281"
ID=INTEGER|2145157206
Name=STRING|"Rename Files (improved)"
line0=STRING|"G:\025837611.tif, G:\113.tif"
line1=STRING|"G:\02583768.tif, G:\114.tif"
Enabled=INTEGER|0
Name=STRING|"Show ""{CURRENTFILENAME(0)}"""
msg0=STRING|"{CURRENTFILENAME(0)}"
msg1=STRING|"{CURRENTFILENAME(1)}"
msgcount=STRING|"2"
file0=STRING|"{CURRENTFILENAME(0)}"
mask=STRING|"{CURRENTFILENAME(1)}"
subdirs=STRING|"0"
dondada
Rename Files
Post by dondada »
Yes, please write a task that uses the "search for" action and then generates a filename to rename and save the found file(s). Thanks!
Rename Files
Which algorithm do you want to use to form new filename? I can offer you to use a sequence number of file. See task below.
;* Do not edit!       *
ExternalName=STRING|"Task282"
ID=INTEGER|1685558832
Name=STRING|"Rename files by number"
Name=STRING|"Delete File"
Count=STRING|"1"
deletedirs=STRING|"0"
file0=STRING|"c:\filelist.txt"
subdir=STRING|"0"
ToRecycleBin=STRING|"0"
Name=STRING|"Create File List (c:\filelist.txt)"
After=STRING|"0"
aftercount=STRING|"0"
AfterLine=STRING|"0"
Before=STRING|"0"
beforecount=STRING|"0"
BeforeLine=STRING|"0"
date1=STRING|"20050716"
date2=STRING|"20050716"
destfile=STRING|"c:\filelist.txt"
file0=STRING|"C:\temp\*.txt"
subdirs=STRING|"0"
Name=STRING|"Set variable ""NUMFILE"" with value ""1"""
varname=STRING|"NUMFILE"
varvalue=STRING|"1"
file=STRING|"C:\filelist.txt"
sourcetext=STRING|"0"
mask=STRING|"{numfile}.txt"
subdirs=STRING|"0"
Name=STRING|"Increment variable ""numfile"""
incement=STRING|"1"
vaiable=STRING|"numfile"
