Start Task from Batch and Assign Value to Variable
jrunkel
Post by jrunkel »
Hi there,
thanks for the wonderful software!
We build a nice task with several actions and use 2 local variables in it. Now we created a batch file to run that task (menu "Create Batch File"). How can we specify the value of the variables in the batch file? We need this because the values of the variables must be changable without user interaction.
We tried:
.../RoboTask.exe $TASKID123 MyVar1=Value MyVar2=Else
but without success.
Please help!
jrunkel
Re: Start Task from Batch and Assign Value to Variable
You can't start the task with parameters from batch file right now.
I wrote this into our ToDo.
But now you can write some file in the batch file and run the task.
The task should read this file and use this data. Lets 1-st lite is the 1-st parameter, 2-nd line - second parameter and so on
Look at my example below
The task:
ExternalName=STRING|"Task54"
ID=INTEGER|-984000395
Name=STRING|"Run task with from batch file"
Name=STRING|"TXT Extract Line (param1)"
external=STRING|"1"
filename=STRING|"{TempDir}\param.txt"
linecount=STRING|"0"
linenum=STRING|"1"
variable=STRING|"param1"
Name=STRING|"TXT Extract Line (param2)"
external=STRING|"1"
linenum=STRING|"2"
variable=STRING|"param2"
Name=STRING|"TXT Extract Line (Param3)"
external=STRING|"1"
linenum=STRING|"3"
variable=STRING|"param3"
Name=STRING|"Show ""Param1 = {param1}"""
msg0=STRING|"Param1 = {param1}"
msg1=STRING|"Param2 = {param2}"
msg2=STRING|"Param3 = {param3}"
msgcount=STRING|"3"
The batch file to run it
echo This parameter1 > %temp%\param.txt
echo parameter2 - just some string>> %temp%\param.txt
echo Hello world!!! >> %temp%\param.txt
"C:\Program Files (x86)\RoboTask\RTaskRun.exe" -984000395
To change parameters you need to change BAT or CMD file only
juanlu
Post by juanlu »
Oleg wrote:You can't start the task with parameters from batch file right now.
Is this already available in the latest release?
If not, is there an estimated timeline?
No, sorry.
