noticed that Robotask support oracle sql?
helenharry
Post by helenharry »
Hi, I'm trialing this program and noticed that Robotask support oracle sql? my query for oracle doesn't seem to work:
spool C:\Users\VM\Desktop\QueryExport\data.csv
select DEPTNO from DEPT
1. Can someone please confirm if Robotask doesn't support Oracle SQL
2. What would be the appropriate way to write the query above?
Thank you in advanced! :)
Re: noticed that Robotask support oracle sql?
Yes, RoboTask supports Oracle Database. But RoboTask uses Windows™ ADO engine to access data (not directly through native Oracle client).
The command SPOOL is not SQL command. Also your expression contains two commands: SPOOL and SELECT
It seems you want to export data from SQL query to CSV file.
You can write simple task to do this
Look at my simple example
ExternalName=STRING|"Task532"
ID=INTEGER|1591169541
Name=STRING|"Write data to CSV"
Name=STRING|"Set variable ""CSV_FILE"" with value ""C:\Users\VM\Desktop\QueryExport\data.csv"""
varname=STRING|"CSV_FILE"
varvalue=STRING|"C:\Users\VM\Desktop\QueryExport\data.csv"
Name=STRING|"Dataset Loop"
commatext=STRING|"0"
connectionstring=STRING|"Provider=MSDAORA.1;User ID=scott;Data Source=Myserver;Persist Security Info=False;password=tiger"
override=STRING|"0"
paramcount=STRING|"0"
password=STRING|"1928821129195921933620110"
sql=STRING|"""select DEPTNO from DEPT"""
timeout=STRING|"60"
var2=STRING|"FIELDS"
withmemo=STRING|"0"
Name=STRING|"Create text file {CSV_file}"
encode=STRING|"0"
fileexists=STRING|"1"
filname=STRING|"{CSV_file}"
line0=STRING|"{Fields}"
suppress=STRING|"1"
