append variable to filename process
snick
Post by snick »
Hi there, I have created a process to rename files, what I want to have happen is to rename files with the variable I gather from the user input dialog
so myvariableFILENAME.EXT
I cant figure out how to pass the original filename to the rename process.
I am probably being dumb but I cant see it!
Thanks
Re: append variable to filename process
Look at my example. I hope this helps
ExternalName=STRING|"Task545"
ID=INTEGER|1106714061
Name=STRING|"add prefix to file name"
Name=STRING|"Create local variable ""FILENAME"" with value ""FILENAME.EXT"""
varname=STRING|"FILENAME"
varvalue=STRING|"FILENAME.EXT"
Name=STRING|"Input Box"
default=STRING|"none"
password=STRING|"0"
prompt=STRING|"Enter the prefix"
variable=STRING|"PREFIX"
value1=STRING|"{prefix}"
value2=STRING|"none"
ActionID=STRING|"A_FLOW_EXIT"
Name=STRING|"Exit"
Name=STRING|"Set variable ""NEWNAME"" with value ""{prefix}{filename}"""
varname=STRING|"NEWNAME"
varvalue=STRING|"{prefix}{filename}"
Name=STRING|"Show ""Old name: {filename}"""
msg0=STRING|"Old name: {filename}"
msg1=STRING|"New name: {newname}"
msgcount=STRING|"2"
Save the text of the task to a file and use menu Task -> Import to import it into RoboTask
snick
Post by snick »
Thanks Oleg, I think I see the logic of that, but where I am now stuck is how to apply this process in the context of my existing one.
Currently I monitor a folder that is an SD Card, so if its inserted, RoboTask creates a list of files of the pattern - P*.MP4 - then renames those (on the card)
Once that is done I will copy those files to a network mapped drive.
My experience is with Apple Automator so this is still a little unfamiliar to me, how would I achieve that?
snick
Post by snick »
I should add that the UNKNOWN IF Then parts in the task - I assume I need to put some process in there right? But again not clear what that is.
For a future update, would it make sense to tweak the rename function to add append text to existing filename?
Thats something that you can do in a few other automation applications and might avoid the complexity of the process and lighten up your excellent support workload.
it seem you work with RoboTask Lite
Try this example
password=STRING|"0"
msgcount=STRING|"2"
Also look at this example below.
It is not trivial but it should work with RoboTask Lite.
The task creates the list of filed and batch file for renaming.
Then it run CMD file.
CatID=INTEGER|1604865554
ExternalName=STRING|"Task546"
ID=INTEGER|-793738978
Name=STRING|"add prefix for Lite version"
Name=STRING|"Change Folder (D:\incoming\test)"
folder=STRING|"D:\incoming\test"
ActionID=STRING|"A_MISC_RUNCONSOLEAPP"
Name=STRING|"Run command-line utility: cmd /c dir /b *.txt >list"
convertansi=STRING|"0"
ifnonzero=STRING|"0"
params=STRING|"/c dir /b *.txt >list"
program=STRING|"cmd"
saveexitcode=STRING|"0"
saveoutput=STRING|"1"
password=STRING|"0"
Name=STRING|"Create text file MyRename.cmd"
encode=STRING|"0"
fileexists=STRING|"0"
filname=STRING|"MyRename.cmd"
line0=STRING|"@echo off"
line1=STRING|":m1"
line2=STRING|"set fff="
line3=STRING|"set /p fff=Input file"
line4=STRING|"if ""%fff%""=="""" goto end"
line5=STRING|"ren ""%fff%"" ""{prefix}%fff%"""
line6=STRING|"goto m1"
line7=STRING|":end"
linecount=STRING|"8"
suppress=STRING|"0"
Name=STRING|"Run command-line utility: cmd /c myrename.cmd < list"
params=STRING|"/c myrename.cmd < list"
