Move + Rename always deletes the first letter
Peter
Post by Peter »
I have a task that always deletes the first letter of the filename after renaming it. Do you have any idea?
Files: D:\cloud\Upload\Temp\Incoming\INFO_*.*
Destination: D:\cloud\School\blabla\management\2018-19
Rename to: {DateTimeToFormat({Date},yyyymmdd)}_*.*
Thanks in advance
Chris
Re: Move + Rename always deletes the first letter
What the initial file name?
Give me some examples for investigation, please
Auto-renaming by mask works with its own algorithms. This algorithm is very similar to system command REN (rename)
Maybe it doesn't correspond to your purposes.
In this case you have to calculate new file name before renaming
Look at this example
ExternalName=STRING|"Task538"
ID=INTEGER|1319745359
Name=STRING|"rename"
Name=STRING|"Create local variable ""OLDFILENAME"" with value ""D:\cloud\Upload\Temp\Incoming\INFO_MyFilenameExample.txt"""
varname=STRING|"OLDFILENAME"
varvalue=STRING|"D:\cloud\Upload\Temp\Incoming\INFO_MyFilenameExample.txt"
Name=STRING|"//calculate new file name"
comment=STRING|"calculate new file name"
Name=STRING|"Set variable ""NEWFILENAME"" with value ""{DateTimeToFormat({Date},yyyymmdd)}_{ExtractFileName({OldFileName})}"""
varname=STRING|"NEWFILENAME"
varvalue=STRING|"{DateTimeToFormat({Date},yyyymmdd)}_{ExtractFileName({OldFileName})}"
Name=STRING|"Show ""{OldFileName}"""
msg0=STRING|"{OldFileName}"
msg1=STRING|"rename to {newfilename}"
msgcount=STRING|"2"
So, you have to move and rename files in the loop one-by-another.
You need calculate new filename for each file and put new file name explicitly
your task will look like this:
ExternalName=STRING|"Task539"
ID=INTEGER|-456484871
Name=STRING|"rename in the loop"
Name=STRING|"File Loop"
date1=STRING|"20181027"
date2=STRING|"20181027"
destvar=STRING|"OLDFILENAME"
DuringMinutes=STRING|"1"
file0=STRING|"D:\cloud\Upload\Temp\Incoming\INFO_*.*"
searchkind=STRING|"0"
sort=STRING|"0"
sortby=STRING|"0"
sortorder=STRING|"0"
subdirs=STRING|"1"
timesize=STRING|"0"
Name=STRING|"//move and rename"
comment=STRING|"move and rename"
ActionID=STRING|"A_FILE_COPY"
Name=STRING|"Copy/Move File"
destdir=STRING|"D:\cloud\School\blabla\management\2018-19"
f_count=STRING|"1"
file0=STRING|"{OldFileName}"
hidden=STRING|"1"
ifexists=STRING|"1"
move=STRING|"1"
rename=STRING|"1"
renamemask=STRING|"{NewFileName}"
subdir=STRING|"0"
system=STRING|"1"
Save the text of the tasks to a file and use menu Task->Import to import the task into RoboTask.
Peter
Post by Peter »
Hi!
Sorry that I respond so late.
Newfile: .\Incoming\Info_*.* (with Monitor it checks for new arrivals)
Destination: .\2018_19
RENAME to
Option: MOVE
Again: It does everything fine.... but leaves the first letter of every file name after the underscore (_)
paraffin
Post by paraffin »
Hi
I am getting the same issue, if I rename the following file
ACCRUAL-HIGH-VALUE_20210614110613.csv
with a P2G_*.* I end up with a file called
PSG_UAL-HIGH-VALUE_20210614110613.csv
In my case this is removing the 4 Characters which is the same as the the amount of characters I want to add.
Any help appreciated at this seemed like the simple part of the routine
You have to do this in the loop. This is similar to previous example (see task below)
CatID=INTEGER|1163085779
ExternalName=STRING|"Task1412"
file0=STRING|"D:\Temp\111\*.*"
sort=STRING|"0"
sortby=STRING|"0"
subdirs=STRING|"1"
timesize=STRING|"0"
Name=STRING|"Set variable ""NEWFILENAME"" with value ""P2G_{ExtractFileName({OldFileName})}"""
varvalue=STRING|"P2G_{ExtractFileName({OldFileName})}"
Name=STRING|"//rename"
Name=STRING|"Rename File"
ifexists=STRING|"0"
subdirs=STRING|"0"
