moving files up one level without knowing parent folder name
PPX
Post by PPX »
hi - I don't know the parent folder name and I need to move files in the child folder up.
I am trying
but I get errors such as
'The system cannot move the file to a different disk drive.'
I am running it with a file loop, tried both with full path and without full path.
when using wildcards on standalone copy/move file, it works.
is there some workaround?
I have full permissions, but the parent folder is variable out of my scope
Thx.
Re: moving files up one level without knowing parent folder
If you know the file so you know the folder. Also you can calculate the parent folder.
Could you send your example. It seems I don't understand your problem correctly...
Look at my example. It works
ExternalName=STRING|"Task534"
ID=INTEGER|1870600849
Name=STRING|"Move to parent"
Name=STRING|"Change Folder (d:\temp\111)"
folder=STRING|"d:\temp\111"
ActionID=STRING|"A_FILE_COPY"
Name=STRING|"Copy/Move File"
destdir=STRING|".."
f_count=STRING|"1"
file0=STRING|"test.txt"
hidden=STRING|"1"
ifexists=STRING|"0"
move=STRING|"1"
rename=STRING|"0"
renamemask=STRING|"*.*.new"
subdir=STRING|"0"
system=STRING|"1"
