how check if variable exists
theimer
Post by theimer »
hello,
exist any way how to how check if variable exists? I tried "If is empty", but it does not operate.
Libor
Re: how check if variable exists
Post your task. Makes it easier to exactly answer your question.
You can use this script top check
function CheckVar(VarName)
  expr = "{"+VarName+"}"
  s = RoboTaskApp.ExpandText(expr)
  if  s = expr then
    CheckVar = "False"
  else
    CheckVar = "True"
  end if
end Function
'LogMessage(CheckVar("date"))
If variable exists then ExpandText method returns the value of variable. Otherwise it keeps the expression unchanged
Also look at the example below
CatID=INTEGER|1604865554
ExternalName=STRING|"Task414"
ID=INTEGER|-1593153984
Name=STRING|"Check existence of variables"
Name=STRING|"Text Loop"
destvar=STRING|"VARNAME"
line0=STRING|"Date"
line1=STRING|"MyVarName"
line2=STRING|"DateTime"
linecount=STRING|"3"
sourcetext=STRING|"1"
Name=STRING|"VB Evaluate (check existence)"
expression=STRING|"CheckVar(""{VarName}"")"
line00000000=STRING|"function CheckVar(VarName)"
line00000001=STRING|"  expr = ""{""+VarName+""}"""
line00000002=STRING|"  s = RoboTaskApp.ExpandText(expr)"
line00000003=STRING|"  if  s = expr then"
line00000004=STRING|"    CheckVar = ""False"""
line00000005=STRING|"  else"
line00000006=STRING|"    CheckVar = ""True"""
line00000007=STRING|"  end if"
line00000008=STRING|"end Function"
line0000000A=STRING|"'LogMessage(CheckVar(""date""))"
linecount=STRING|"11"
loadfromfile=STRING|"1"
variable=STRING|"res"
value1=STRING|"{res}"
Name=STRING|"Show ""Variable {VarName} exists"""
msg0=STRING|"Variable {VarName} exists"
ActionID=STRING|"A_FLOW_ELSE"
Name=STRING|"Else"
Name=STRING|"Show ""Variable {VarName} doesn't exist!!!"""
icon=STRING|"3"
msg0=STRING|"Variable {VarName} doesn't exist!!!"
Maybe it's necessary to add such action. I wrote this into our ToDo.
theimer
Post by theimer »
thank you very much
