Import Tasks and Variables from command line
bgkaufhold
Post by bgkaufhold »
i want to know if there's a way to import files directly from the install process (or later) but from the command line.
I want to make a ".bat" in a way that the end-users cant see all the process of installation and do not have to import manually the tasks / global variables.
Is it possibly?
Thanks!
Re: Import Tasks and Variables from command line
To import necessary tasks from command line
- stop RoboTask
- copy files to task's folder
- start RoboTask again
How to find task folder read here
All global variables are in system registry:
HKEY_CURRENT_USER\Software\Neowise\RoboTask\User variables
Just export this data into REG file.
To import it form command line use command line
reg import <reg_file_name>
- stop RoboTask
- import registry data
