Variable Time Difference
chrisk1
Post by chrisk1 »
I have a simple task for calculating the run time of a task.
Set a var with DateTime at the Start, set a different var with DateTime at the end.
Store the result from Time Difference in a Third var.
For some reason, the result is always 0. Any ideas?
*NOTE: This example doesn't have a pause, but I tested this with a 30 second pause"
CatID=INTEGER|0
ExternalName=STRING|"Task6"
ID=INTEGER|1778460593
Name=STRING|"Time Difference Task"
Name=STRING|"Create local variable ""START_TASK"" with value ""{DateTime}"""
varname=STRING|"START_TASK"
varvalue=STRING|"{DateTime}"
Name=STRING|"Show ""[{Start_Task}]"" and play sound"
msg0=STRING|"[{Start_Task}]"
msg2=STRING|"START"
msgcount=STRING|"3"
playsound=STRING|"1"
Name=STRING|"Create local variable ""END_TASK"" with value ""{DateTime}"""
varname=STRING|"END_TASK"
Name=STRING|"Show ""[{End_Task}]"" and play sound"
msg0=STRING|"[{End_Task}]"
msg2=STRING|"END"
msgcount=STRING|"3"
ActionID=STRING|"A_TIMEDIFFERENCE"
Name=STRING|"Time Difference"
datetime1=STRING|"{START_TASK}"
datetime2=STRING|"{END_TASK}"
format=STRING|"0"
valuekind=STRING|"0"
varname=STRING|"TASK_TIME"
Name=STRING|"Show ""[{Task_Time}]"" and play sound"
msg0=STRING|"[{Task_Time}]"
msg2=STRING|"Time to Complete!"
msgcount=STRING|"3"
Re: Variable Time Difference
Pay attention to this option, please
If it is ON then the action calculates the value and save the result into variable
If it is OFF then the action saves specified string as-it-is. So you get the current date-time value in variable START_TASK, because RoboTask calculates the value every time when you use this variable.
Read more details here: https://robotask.com/forum/viewtopic.php?f=1&t=2359
Also see your corrected task below
ExternalName=STRING|"Task22"
Name=STRING|"Time Difference Task (corrected)"
msg2=STRING|"START"
msgcount=STRING|"3"
msg2=STRING|"END"
msgcount=STRING|"3"
format=STRING|"0"
msgcount=STRING|"3"
