Error Handling
paraffin
Error Handling
Post by paraffin »
Hi
Has anyone got an example of error handling that will allow me to only send an email alert when the job fails 3 times in a row?
We are working with a provider that has an SFTP server and it seems that on occasion it gets a bit flakey so I am getting a lot of alerts for a period and then it resolves itself.
Cheers in advance
David
Re: Error Handling
You can use global variable some counter. For example variable named GlobalCounter with initial value 1
And use it in error handler as in my example
CatID=INTEGER|1075658632
ExternalName=STRING|"Task519"
ID=INTEGER|-366427919
Name=STRING|"handler send a message at 3-d time"
type=STRING|"1"
value1=STRING|"{GLOBALCOUNTER}"
value2=STRING|"3"
Name=STRING|"//send a message and reset global counter"
comment=STRING|"send a message and reset global counter"
defh=STRING|"1"
defw=STRING|"1"
duration=STRING|"5"
height=STRING|"76"
icon=STRING|"2"
kind=STRING|"0"
message=STRING|"Error raised 3 times"
position=STRING|"3"
title=STRING|"3-d time"
width=STRING|"330"
Name=STRING|"Set variable ""GLOBALCOUNTER"" with value ""1"""
varname=STRING|"GLOBALCOUNTER"
varvalue=STRING|"1"
ActionID=STRING|"A_FLOW_ELSE"
Name=STRING|"Else"
Name=STRING|"Increment variable ""GlobalCounter"""
incement=STRING|"1"
vaiable=STRING|"GlobalCounter"
Do not forget create global variable GlobalCounter with value 1.
Next you can try this example. It shows a message only at 3-d running.
