view or edit global or system variables
theimer
Post by theimer »
when I want to view or edit global or system variables, I have to leave the current task. it is quite uncomfortable. it would be more convenient if the user could see these variables at any time with a hot key
Re: view or edit global or system variables
Or even better, edit it while you are in the task and choosing variables. Like a "in-line" editing.
You can do this right now.
When you choose variable in any action editor you can edit the list of global and local variables
Yes, you are correct.
theimer
Post by theimer »
yes, it is also the way how to do it
thank you
juanlu
Post by juanlu »
True.
A hotkey would be great, though. The global variables window is probably one of the most used in RoboTask...
