First business day of month
Hey Oleg,
You know my programming skills s**k very hard, and you have recently created a script which determines the last business day of the month in JS Script. You guess it, now it's time to determine the first business day of the month :D
Also in this case it's used to set a variable to "yes" if it's the case.
I was playing around with the offset for a long time, tried another script, and anotherone, but I failed (ofcourse) to get it done. Can you help me out?
This was the code for the last business day (I already renamed the function):
function FirstBusinessDayOfMonth(year, month) {
var date = new Date();
var offset = 0;
var result = null;
if ('undefined' === typeof year || null === year) {
year = date.getFullYear();
if ('undefined' === typeof month || null === month) {
month = date.getMonth();
do {
result = new Date(year, month, offset);
offset--;
} while (0 === result.getDay() || 6 === result.getDay());
return result.getVarDate();
//LogMessage(FirstBusinessDayOfMonth(2018, 4))
Re: First business day of month
Use this script
  var offset = 1;
  var result = null;
  do
    offset++;
  //while Saturday or Sunday
//LogMessage(FirstBusinessDayOfMonth(2018, 8))
Also see the example below
CatID=INTEGER|1075658632
ExternalName=STRING|"Task513"
ID=INTEGER|-1915200085
Name=STRING|"First business day"
ActionID=STRING|"A_SCRIPT_JSEVALUATE"
Name=STRING|"JS Evaluate"
expression=STRING|"FirstBusinessDayOfMonth(2018, 8)"
line00000000=STRING|"function FirstBusinessDayOfMonth(year, month)"
line00000001=STRING|"{"
line00000002=STRING|"  var date = new Date();"
line00000003=STRING|"  var offset = 1;"
line00000004=STRING|"  var result = null;"
line00000006=STRING|"  if ('undefined' === typeof year || null === year)"
line00000007=STRING|"  {"
line00000008=STRING|"    year = date.getFullYear();"
line00000009=STRING|"  }"
line0000000B=STRING|"  if ('undefined' === typeof month || null === month)"
line0000000C=STRING|"  {"
line0000000D=STRING|"    month = date.getMonth();"
line0000000E=STRING|"  }"
line00000010=STRING|"  do"
line00000011=STRING|"  {"
line00000012=STRING|"    result = new Date(year, month, offset);"
line00000013=STRING|"    offset++;"
line00000014=STRING|"  } while (0 === result.getDay() || 6 === result.getDay());"
line00000015=STRING|"  //while Saturday or Sunday"
line00000017=STRING|"  return result.getVarDate();"
line00000018=STRING|"}"
line0000001A=STRING|"//LogMessage(FirstBusinessDayOfMonth(2018, 8))"
linecount=STRING|"27"
loadfromfile=STRING|"1"
variable=STRING|"res"
message=STRING|"{res}"
Year - full year
Month - from 0 to 11 (0-January, ..., 11 - December)
Ofcourse.....so simple. It's working. I saw that only the offset was changed and the increments of it. A programmer will see it straight away, for my brains that will never happen!
Thanks anyway.
