add date/time stamp to file name
kevins
Post by kevins »
I am trying to add the current date/time stamp to a filename using the variables. I only seem to be able to add the date.
thanks,
Kevin
Re: add date/time stamp to file name
Look at my example below
CatID=INTEGER|1251730006
ExternalName=STRING|"Task182"
ID=INTEGER|-1820018450
Name=STRING|"date stamp into filename"
Name=STRING|"Create local variable ""OLDNAME"" with value ""c:\myfolder\FileName.txt """
varname=STRING|"OLDNAME"
varvalue=STRING|"c:\myfolder\FileName.txt "
Name=STRING|"Set variable ""NEWNAME"" with value ""{ExtractFilePath({oldname})}\{ExtractFileNameNoExt({oldname})}-{DateTimeToFormat({Date},yyyy-mm-dd)}.{ExtractFileExt({oldname})}"""
varname=STRING|"NEWNAME"
varvalue=STRING|"{ExtractFilePath({oldname})}\{ExtractFileNameNoExt({oldname})}-{DateTimeToFormat({Date},yyyy-mm-dd)}.{ExtractFileExt({oldname})}"
Name=STRING|"Show ""Old name: {OldName}"""
msg0=STRING|"Old name: {OldName}"
msg1=STRING|"New name: {NewName}"
msgcount=STRING|"2"
RichardD
Post by RichardD »
Thanks for info! :)
