Alert if Text Found in a TXT File
kerrycwh
Post by kerrycwh »
I would like to have a file monitored in our logs and if a certain string of text appears (which will inhibit other processes) then have an alert sent.
Specially check a file called AdventImportLog.txt and if it ever reads... 'Error: 1 Duplicate holdings found' to then send an email to my team alerting them that. We have sent other alerts via email and it works great. But was not sure about the reading thru text.
Thanks!
Kerry
Re: Alert if Text Found in a TXT File
The simplest way is below.
You can attach some trigger the the task or run this task when you command line finished.
This is optimal way if the file is not very large
CatID=INTEGER|1075658632
ExternalName=STRING|"Task509"
ID=INTEGER|1194659953
Name=STRING|"alert if some text found"
Name=STRING|"Create local variable ""FILENAME"" with value ""c:\temp\AdventImportLog.txt"""
varname=STRING|"FILENAME"
varvalue=STRING|"c:\temp\AdventImportLog.txt"
operator=STRING|"6"
value1=STRING|"Error: 1 Duplicate holdings found"
value2=STRING|"{TextFile({Filename})}"
Name=STRING|"Send Email"
attachcount=STRING|"0"
auth=STRING|"0"
charset=STRING|"iso-8859-1"
from=STRING|"user@myhost.com"
host=STRING|"server.com"
html=STRING|"0"
msg0=STRING|"Found error in the log"
passwordmode=STRING|"0"
port=STRING|"25"
priority=STRING|"1"
receipt=STRING|"0"
SSL=STRING|"0"
subject=STRING|"Error alert "
to=STRING|"admin@myhost.com"
xmailer=STRING|"RoboTask"
Pay attention that this is example only. You have to change parameters to yours.
kerrycwh
Post by kerrycwh »
hello,
i will try this, thank you. i copy and pasted into a txt file and then imported into Robotask, but should the extension be different?
can you also be more specific to what to change? i see 4 actions in there. i would like to do a file monitor to basically first see when the file changes, and then run the text scan. could i just do a trigger of file monitor and then action 2, and action 3?
... but should the extension be different?
The extension doesn't matter. The task is text only
...can you also be more specific to what to change?
I think that you have to change file path in step #1 and email parameters in step #3
