file uploading automation
hoangnganvy1993
Post by hoangnganvy1993 »
Just got the RoboTask, and trying it for size in my setup.
I need to be able for it to detect a file change, or a new file created, and upload it to the server using ftp while preserving and creating directories on the server as needed.
Doable?
thanks,
ark
Re: file uploading automation
I recommend you to use SSL FTP actions. The support plain FTP too.
To preserve directory structure use SSL FTP Synchronization action.
It will upload all new files to FTP from specified folder.
To detect changes in source folder use File Monitor trigger
