Xpath
theimer
Xpath
Post by theimer »
is there any way using Xpath in Robotask? many problems can be solved using RegExp, but in some cases Xpath would save a lot of work.
Best regards,
Libor
Re: Xpath
RoboTask contain XML documents plugin. It can extract XML nodes by path and mask in the loop
Also maybe some command-line utilities can help you? For example XMLStarlet Command Line toolkit
theimer
Re: Xpath
Post by theimer »
xpath can also be used also to parse html pages. I'm not sure if xml document plug-in can be used for parsing html. thank you for the tip on the XMLStarlet Command Line toolkit. I will look at it.
thank you very much
Libor
