Multi-choice Dialog
theimer
Multi-choice Dialog
Post by theimer »
is there any way how to set Captions and Variables programmatically in Multi-choice Dialog? I am selecting some data from DB and I dont know how many and which records I will get so I cant set Captions and Variables manually in advance.
it looks it is possible only in Choice dialog (singl choice), but I need it in Multi-choice Dialog.
Thanks for any ideas
Libor
Re: Multi-choice Dialog
Unfortunately not as yet.
Probably we'll implement this in next release.
theimer
Post by theimer »
Thanks for the information. it would be very useful to add this function to the robotask because it is not currently possible to interactively select from more dynamically generated options.
