FTP File Exists
fordj36
FTP File Exists
Post by fordj36 »
Sorry this may have been asked before, but I can't find it. I need to check a remote ftp service for a particular file.
When I use the "FTP File Loop" task if I put the file name in the "Remote Folder and File Mask" box it doesn't find the file.
But if I put *.msg in the box it finds the file.
esantos
Re: FTP File Exists
Post by esantos »
I have the same doubt.
Re: FTP File Exists
Will be in next release in sFTP and SSL FTP actions
Now you can check the existence of the file by standard algorithm in the loop.
Look at my example:
CatID=INTEGER|799993286
ExternalName=STRING|"Task544"
ID=INTEGER|-1079361276
Name=STRING|"FTP check file existence"
Action14=FOLDER
Action15=FOLDER
Name=STRING|"Set variable ""TESTFILENAME"" with value ""test.txt"""
varname=STRING|"TESTFILENAME"
varvalue=STRING|"test.txt"
value1=STRING|"{Exist}"
Name=STRING|"Show ""File ""{TestFileName}"" exists"""
[Actions\Action12\Params]
msg0=STRING|"File ""{TestFileName}"" exists"
ActionID=STRING|"A_FLOW_ELSE"
Name=STRING|"Else"
[Actions\Action14]
Name=STRING|"Show ""File ""{TestFileName}"" doesn't exist"""
[Actions\Action14\Params]
icon=STRING|"3"
msg0=STRING|"File ""{TestFileName}"" doesn't exist"
[Actions\Action15]
Name=STRING|"Set variable ""EXIST"" with value ""FALSE"""
varname=STRING|"EXIST"
varvalue=STRING|"FALSE"
ActionID=STRING|"A_SSLFTP_LOGON"
Name=STRING|"SSL FTP Log On"
anonymous=STRING|"1"
host=STRING|"ftp.company.com"
passive=STRING|"1"
port=STRING|"21"
proxypassword=STRING|"2591325970249442622624944"
proxytype=STRING|"3"
tlsmode=STRING|"0"
useproxy=STRING|"0"
username=STRING|"anonymous"
usessl2=STRING|"0"
usessl3=STRING|"0"
usestls=STRING|"1"
usestls11=STRING|"1"
usestls12=STRING|"1"
ActionID=STRING|"A_SSLFTP_CHANGEFOLDER"
Name=STRING|"SSL FTP Change Folder"
folder=STRING|"testfolder"
ActionID=STRING|"A_SSLFTP_FILELOOP"
Name=STRING|"SSL FTP File Loop"
date1=STRING|"18991230"
date2=STRING|"18991230"
DuringMinutes=STRING|"1"
filenameonly=STRING|"0"
folder=STRING|"{TestFileName}*"
kind=STRING|"0"
sizesave=STRING|"0"
sort=STRING|"0"
sortby=STRING|"0"
sortorder=STRING|"0"
subfolders=STRING|"0"
timesave=STRING|"0"
varname=STRING|"FTPFILE"
value1=STRING|"{TestFileName}"
value2=STRING|"{ftpfile}"
Name=STRING|"Set variable ""EXIST"" with value ""TRUE"""
varvalue=STRING|"TRUE"
Name=STRING|"Break"
You can use SSL FTP actions for plain FTP protocol too.
esantos
Re: FTP File Exists
Post by esantos »
Hello oleg, thanks for the script, it will be useful to me.
When I use sFTP, I use the ls command to list the contents of the folder and play this content to a variable, so I do an if to confirm if the file I want is in sFTP. Could you add the variable option also for FTP and SSL FTP?
