Generate task index for organisation, archive, etc
PPX
Post by PPX »
Hello, I would like to share this simple task.
It will scan your task folder for any .tsk files and extract from them the internal and external task names alongside the actual filenames and put them in a text file in the task folder.
It should be amended to customise the delimiters and of course make personal the paths. I recommend keeping the index filename the same as it will come at or near the top of the file list when sorted by name (ascending).
I wrote this because I am archiving tasks and want to see at a glance what tasks are held in an archive, as I like to keep my working list of tasks concise so I am deleting any not in active use, while I may wish to retrieve it later and re-use it - this is not possible with the raw filenames, yet can also be done via a content search of the files - I would like to see them all in summary instead.
TSK-INDEXER.zip
TASK-INDEXER
(1.69 KiB) Downloaded 1094 times
Re: Generate task index for organisation, archive, etc
Thank you.
Also I can share the task which creates CSV text with information
  • Task file name
  • Task name
  • Task External name
You can open this CVS file in Excel and sort the list by any column
The task creates file MAP.CSV in task's folder
CatID=INTEGER|1604865554
ExternalName=STRING|"Task297"
ID=INTEGER|-697266192
Name=STRING|"Retrieve task parameters to CSV"
Name=STRING|"VB Script"
expandvars=STRING|"0"
line00000000=STRING|"txt = """""
line00000001=STRING|"for i=0 to RoboTaskApp.TaskCount - 1 step 1"
line00000002=STRING|"  id = RoboTaskApp.TaskInfoID(i)"
line00000003=STRING|"  nam = RoboTaskApp.TaskInfoName(i)"
line00000004=STRING|"  ext = RoboTaskApp.TaskInfoExtname(i)"
line00000006=STRING|"  filename = Hex(id)"
line00000007=STRING|"  while len(filename) < 8"
line00000008=STRING|"    FileName = ""0"" + FileName"
line00000009=STRING|"  wend"
line0000000A=STRING|"  'txt = txt + RoboTaskApp.ExpandText(""{TaskFolder}"") + ""\"" + filename + _"
line0000000B=STRING|"  ' "".tsk = "" + nam + chr(13) + chr(10)"
line0000000C=STRING|"  txt = txt + filename + ""|"" + nam + ""|"" + ext + chr(13) + chr(10)"
line0000000D=STRING|"next"
line0000000F=STRING|"RoboTaskApp.SetUserVariable ""text"", txt"
linecount=STRING|"17"
savescript=STRING|"0"
ActionID=STRING|"A_STR_TRIM"
Name=STRING|"STR Trim"
custom=STRING|"0"
eol=STRING|"1"
lead=STRING|"1"
source=STRING|"{#text}"
spaces=STRING|"1"
tabs=STRING|"1"
trailing=STRING|"1"
variable=STRING|"text"
Name=STRING|"Create local variable ""CSVTEXT"" with value """""
varname=STRING|"CSVTEXT"
Name=STRING|"Text Loop"
destvar=STRING|"LINE"
line0=STRING|"{#text}"
sourcetext=STRING|"1"
colon=STRING|"0"
comma=STRING|"0"
other=STRING|"1"
otherchar=STRING|"|"
quote=STRING|"0"
semocolon=STRING|"0"
space=STRING|"0"
spaceasone=STRING|"0"
string=STRING|"{#Line}"
tab=STRING|"0"
variable=STRING|"Line"
Name=STRING|"Set variable ""CSVTEXT"" with value ""{#CSVText}{#Line}{EOL}"""
varvalue=STRING|"{#CSVText}{#Line}{EOL}"
Name=STRING|"Create text file {TaskFolder}\map.csv"
encode=STRING|"0"
fileexists=STRING|"0"
filname=STRING|"{TaskFolder}\map.csv"
line0=STRING|"{#CSVtext}"
suppress=STRING|"0"
Name=STRING|"Run ""notepad.exe {TaskFolder}\map.csv"""
ifnonzero=STRING|"0"
params=STRING|"{TaskFolder}\map.csv"
program=STRING|"notepad.exe"
runas=STRING|"0"
wait=STRING|"0"
Save the text of the task into a file and use menu Task->Import to import it into RoboTask
PPX
Post by PPX »
Thank you that's great.
