FTP Download
Paul
FTP Download
Post by Paul »
Hi
I need to download all files from a specific folder on an FTP site. What command do i use to automatically select all files, I have tried the normal *.* but it does not work.
Thanks in advance
FTP Download
You must use FTP File loop action
For example see task below.
Save text of task to file and use menu Task|Import to import into RoboTask
;* RoboTask Task file *
;* Do not edit!       *
CatID=INTEGER|565106205
ExternalName=STRING|"Task271"
ID=INTEGER|1210111037
Name=STRING|"FTP File Loop..."
ToLog=INTEGER|1
ActionID=STRING|"A_FTP_LOGON"
Name=STRING|"FTP Log On"
anonymous=STRING|"1"
host=STRING|"localhost"
passive=STRING|"1"
port=STRING|"21"
username=STRING|"anonymous"
Name=STRING|"FTP File Loop"
filenameonly=STRING|"0"
folder=STRING|"*.*"
sizesave=STRING|"0"
subfolders=STRING|"0"
timesave=STRING|"0"
varname=STRING|"FTP_FILE"
message=STRING|"{ftp_file}"
type=STRING|"2"
Paul
FTP Download
Post by Paul »
Hi
Thanks for your response. I dont undrstand the file loop and cant seem to get the download to work. I need to carry out the following task.
1. FTP Log On
2. FTP Change Folder
3. FTP Download all files in the folder to a specified folder on my sever
4. FTP log Off
I can get it all to work except the actual download of all files. Where and how does the file loop go within the actions.
Look forward to your reply
Many Thanks Paul
FTP Download
Ok, see task below.
Loop works so: it repeat actions inside the loop for each file. Name of current file is stored in FTP_FILE variable (see settings of FTP loop action).
;* Do not edit!       *
ExternalName=STRING|"Task272"
ID=INTEGER|4116511
Name=STRING|"FTP File Loop and download"
ToLog=INTEGER|1
passive=STRING|"1"
port=STRING|"21"
ActionID=STRING|"A_FTP_CHANGEFOLDER"
Name=STRING|"FTP Change Folder"
folder=STRING|"/incoming"
folder=STRING|"*.*"
sizesave=STRING|"0"
timesave=STRING|"0"
message=STRING|"downloading file {ftp_file}"
type=STRING|"2"
ActionID=STRING|"A_FTP_DOWNLOAD"
Name=STRING|"FTP Download"
file=STRING|"{ftp_file}"
folder=STRING|"C:\Temp"
ActionID=STRING|"A_FTP_LOGOFF"
Name=STRING|"FTP Log Off"
Paul
FTP Download
Post by Paul »
Hi
Many thanks for your assistance its working fine.
Paul
davidmclark
Re: FTP Download
Post by davidmclark »
Hi. Not sure how to add Tasks to Roboform. But a suggestion. For the FTP tasks would this not be much simpler for a user for you to simply add Recursive downloads similar to how you do it in SFTP or simply add wildcards in the file names?
