Get Inputs From User
ArashEB
Post by ArashEB »
I am working on my new task,I need to get 2 inputs from user and then use them later.
Forexample, the first input will get a username, and the second will get a password.
Then it's gonna paste each input, somewhere else (Like two separated TextAreas, or NotePad files ...)
How can I do it ?!
Re: Get Inputs From User
Look at my example below.
This task inputs username and password and put them into Notepad
ExternalName=STRING|"Task292"
ID=INTEGER|980746290
Name=STRING|"Input username and password and use it"
Name=STRING|"Input Box (username)"
default=STRING|"none"
password=STRING|"0"
prompt=STRING|"Enter the user name (ESC to cancel)"
variable=STRING|"USERNAME"
Name=STRING|"Delay 2 sec"
delay=STRING|"2"
dimension=STRING|"1"
currentwindow=STRING|"1"
fixedwindow=STRING|"0"
keylayout=STRING|"0"
keys=STRING|"""Username: {username}"",""Password: {password}"""
pause=STRING|"20"
release=STRING|"0"
sendkind=STRING|"0"
wincaption=STRING|"Notepad"
value1=STRING|"{username}"
value2=STRING|"none"
ActionID=STRING|"A_FLOW_EXIT"
Name=STRING|"Exit"
Name=STRING|"Input Box (password)"
password=STRING|"1"
prompt=STRING|"Enter the password (ESC to cancel)"
variable=STRING|"PASSWORD"
value1=STRING|"{password}"
Name=STRING|"Exit"
Name=STRING|"Run ""notepad.exe """
ifnonzero=STRING|"0"
program=STRING|"notepad.exe"
runas=STRING|"0"
wait=STRING|"0"
