SFTP Connect
fneurieser
SFTP Connect
Post by fneurieser »
Hello Oleg,
how does SFTP handle welcome banners on a SFTP-Server?
Is sending SFTP a continue command or not?
Thanks in advance
Franz-Georg
Re: SFTP Connect
sFTP Log On action should ignore the banner. In any case it doesn't handle it.
If you have some problem then I want to see the log of the task with all error messages.
