Command Line
dondada
Command Line
Post by dondada »
Can a Robotask task be run from a Command Line? If so what is the command required?
Command Line
Of course. There is RTaskRun.exe utility for this purpose.
Command line is RTaskRun.exe <TaskID>
TaskId must be in hex or decimal format. For example:
RTaskRun.exe $3C46E896
Where "3C46E896" is a task ID (in hex) and the name of task file.
Remember that task must be registered in RoboTask.
Also you can create a shortcut on desktop for any task. Use menu Task | Create Shortcut on Desktop.
anonymouse
Command Line
Post by anonymouse »
And can the tray icon be hidden?
Command Line
anonymouse wrote: And can the tray icon be hidden?
Why do you want to hide tray icon? If icon is hidden how do you want to control RoboTask?
anonymouse
Command Line
Where are the files that are created or which are the files that are used by 'Install as Service' and how does it differ from normal operation through robotask.exe?
Command Line
When you launch "Install service", no new files will be created.
anonymouse
Command Line
When the install as service shortcut is selected from the start menu, what changes to the existing files, is the only advantage that it runs regardless of who logs in and is the tray icon hidden?
Command Line
When RoboTask works as service it can execute configured tasks even if no users are logged on. RoboTask service will be started together with Windows and you don't need to login to computer.
thomas
Re: Command Line
Post by thomas »
is there a command line parameter to stop and disable a task?
Re: Command Line
No. You can only start some task.
But you can stop or disable another task in this task. See actions Disable task and Stop Task
To create batch file for a task select the task and use menu Task->Create Batch File
