SFTP Reconnect
paraffin
SFTP Reconnect
Post by paraffin »
I am using the SFTP tasks and downloading files but often the SFTP disconnects and the whole task stops.
If I use WinSCP I can see these breaks but WinSCP reconnects and resumes the download.
Is PSFTP capable of this?
If not can I integrate winscp as my SFTP utility?
Cheers
David
Re: SFTP Reconnect
You can use WinSCP as external command-line utility.
Learn more about command-line options of WinSCP here
paraffin
Re: SFTP Reconnect
Post by paraffin »
Thanks Oleg, I was going to give it a try but also going to moan at the SFTP Server guys as something must be happening their side.
Any thoughts on using WinSCP as the SFTP client in RoboTask?
Cheers
P.S Loving the product
