How to close all windows at once?
snowseals
Post by snowseals »
After I'm done with my project , I have a lot of windows/programs open.
To start over, I have to close them all.
But that takes alot of clicks.
Is there a way to create a shortcut like CTRL-SHIFT-X to close all what is opened?
Like a ALT-F4 for all.
We're talking about Google Chrome, 2 instances, Adobe Reader, some CMD console, explorer.exe to show a folder, Sticky Notes.
Re: How to close all windows at once?
You can minimize all widows. Send Win+M key to active window.
In order to close all windows you have to use Window Loop action to enumerate necessary windows
Next use Window Command to close window in the loop one-by-one
Use "Use Window Handle" option and "Close" action.
But be careful, please. You don't need close all windows. You can close some necessary windows too
snowseals
Post by snowseals »
Like this?
CatID=INTEGER|0
ExternalName=STRING|"Task3"
ID=INTEGER|1187257673
Name=STRING|"Close all open windows"
ActionID=STRING|"A_LOOP_WINDOW"
Name=STRING|"Window Loop"
caption=STRING|"0"
captionexact=STRING|"0"
captionfilter=STRING|"0"
class=STRING|"0"
classexact=STRING|"0"
classfilter=STRING|"0"
handlevariable=STRING|"1"
showchild=STRING|"0"
showhidden=STRING|"0"
Name=STRING|"Close window by handle"
action=STRING|"4"
caption=STRING|"1"
child=STRING|"0"
class=STRING|"0"
exact=STRING|"0"
findmode=STRING|"1"
handle=STRING|"1"
hidden=STRING|"0"
processall=STRING|"0"
Your task is wrong.
Variable name can't begin from number
also you have to use variable expression in step #2 See my example below
Also you have to exclude necessary windows in the loop
such as: RoboTask, mail client and other background applications
ExternalName=STRING|"Task174"
Name=STRING|"Close all open windows (corrected)"
caption=STRING|"1"
captionvariable=STRING|"CAPT"
class=STRING|"0"
handlevariable=STRING|"HWND"
operator=STRING|"6"
value1=STRING|"RoboTask"
value2=STRING|"{capt}"
Name=STRING|"//do nothing"
comment=STRING|"do nothing"
ActionID=STRING|"A_FLOW_ELSE"
Name=STRING|"Else"
Name=STRING|"//close the window"
comment=STRING|"close the window"
action=STRING|"4"
caption=STRING|"1"
child=STRING|"0"
class=STRING|"0"
exact=STRING|"0"
findmode=STRING|"1"
handle=STRING|"{hwnd}"
hidden=STRING|"0"
