[Minor bug] Create folder, stays orange
Situation: Automation is disabled. (All folders are grey). When creating a new folder, this folder is orange (which should be gray!)
Enable automation and disable it again makes the folder gray.
Re: [Minor bug] Create folder, stays orange
Thanks.
