Storing and comparing variables
crisp212
Post by crisp212 »
Good night Oleg.
One question: I got this task that checks a website every 1 hour (Makes a f5 and then makes a ctrl+a and then ctrl+c). It stores all values of website (get text), copy its in a txt file (create txt file) and then stores line 51 where my interested value is (TXT Extract Line). The value is stored in variable named "true"
So what I want, is that every hour, after line 51 stored in variable "true", doesn't get overwritten by previous (so it creates first true1, true2, etc...)
Then, I want to be able to minus true1 and true2 and store it in another variable.
Can you help me? Thank you.
Regards,
Crisp212
Re: Storing and comparing variables
Maybe you need something like this (see my example)
This task saves 4 previous values of variable. You have to use global variables (menu Options->Variables and open Global User Variables tab)
To get it work make four global variables VAR1, VAR2, VAR3 and VAR4 with some initial value (for example 0)
CatID=INTEGER|1040932817
ExternalName=STRING|"Task501"
ID=INTEGER|1048493595
Name=STRING|"save several values"
Name=STRING|"Show ""Old Values"""
msg0=STRING|"Old Values"
msg2=STRING|"var1 = {var1}"
msg3=STRING|"var2 = {var2}"
msg4=STRING|"var3 = {var3}"
msg5=STRING|"var4 = {var4}"
msgcount=STRING|"6"
Name=STRING|"Set variable ""VAR4"" with value ""{var3}"""
varname=STRING|"VAR4"
varvalue=STRING|"{var3}"
Name=STRING|"Set variable ""VAR3"" with value ""{var2}"""
varname=STRING|"VAR3"
varvalue=STRING|"{var2}"
Name=STRING|"Set variable ""VAR2"" with value ""{var1}"""
varname=STRING|"VAR2"
varvalue=STRING|"{var1}"
Name=STRING|"Input Box"
default=STRING|"0"
password=STRING|"0"
prompt=STRING|"Input new value for VAR1"
variable=STRING|"VAR1"
Name=STRING|"Show ""New Values"""
msg0=STRING|"New Values"
msgcount=STRING|"6"
To make necessary calculations use VB Evaluate or JS Evaluate actions
crisp212
Post by crisp212 »
Hi Oleg. I'll try. Thanks!
