Robotask is not work
WellWisher
Post by WellWisher »
Hello, help me please, i have this error and my Robotask is not work
E: 08.06.2018 16:49:41: Unhandled exception: Thread creation error: Not enough storage is available to process this command
Re: Robotask is not work
I'm afraid that you have to restart RoboTask to fix the problem.
Menu Task->Exit and start RoboTask again for application
Restart RoboTask Service for system service
A couple questions:
- What version do you use?
- How do you use it: as application or system service?
- what version do you use? (menu Help->About, also see assembly version)
WellWisher
I tried, so do this error every time after a while,
version 7.1.0.951
version assembly 7.1.2.160
run as application
WellWisher
found a problem, this is task "Auto open"
CatID=INTEGER|0
ExternalName=STRING|"Task3"
ID=INTEGER|-1182707550
Name=STRING|"Auto Open"
ToLog=INTEGER|2
ActionID=STRING|"A_FINDBYIMAGE"
Name=STRING|"Find an Element by Image"
generror=STRING|"1"
img00000000=STRING|"eNqVlmlQE2cYx+1MGcoh7AZCuMMdLjkKMUJEJCGGY3cjyJUggQAhAULAEEIQ1FixjhQcO85UiqiI2jr"
img00000001=STRING|"jScEAEfAINuABMkAC9pjafmCmXzrjN/upm4QsuwFqm/nvzm723fnt/3me930fFqxw3WH57UaPSPQIRY"
img00000002=STRING|"8A9Phkh7fl/73rz/E/EFlBBcBGEDYC0DIAL4MfExmZV529gtT1eSCL4H8YbxXKAiwsEDGhMrPMWsILR"
img00000003=STRING|"AVbZX7FC3kFS8+XVFRUNzTurbpNghf+D8sEYjibNTscXlxRJ5PF5uTm0GJjRXJFasnZ7UZin4exMFMY"
img00000004=STRING|"EXOHDsa/6wHP5YrUfJGInkL/fkKfkMZ2dvlMcbwjOe8UCC18FLeRLxSxjrO5s+IsQi8oyCtI0n2Qz3d"
img00000005=STRING|"0dOQWFlzVTmYged6B1J1Onwoksviiq6StcCAOh2NZZYdbH4+eBc0X9nNYgLuTm5vzHnbmwPCjdOigp4"
img00000006=STRING|"8fxZtMoZAqZEfSSs+Btm/DvnATy4TF0OwONpF4lkjaskbmvVF9+a1IKnZwcAgJD/Lx9WLBvOvaqbTcP"
img00000007=STRING|"C9/anBIgJc32cnRQaJqSy7oQoNpR8RweBaACcNByz55c4LWPqG42jeQysqFQmk0FxenTB7v8oOHdHaO"
img00000008=STRING|"f0iYm5tTeFRseFyiOwCWSuSJxddIRByWOHMdwqZ1IaaNaxSHBhM27hM/zMzO8fLxza+UipWtl+5pdyU"
img00000009=STRING|"lw/zSa0Paz/dzA0PD84sKe/oH/SPj49Iyg0NDS2vqg/N1m1moCCyMaIOi7ri1D1KYzL7vbgmqxQP3hk"
img0000000A=STRING|"Stmtqjmqomhe7ps13MjN37WO1dX/XeuCFXd0TQ93KKyqDCwnjhhB1lg2UrQtukXsEShyqj+j6dwTjX2"
img0000000B=STRING|"3vz3tCpC30QX+jhSYaLi29rx9ORImp4lF9AQPNxzZBuEhFKkjKyhTWSaL5uy/q31qG1CEGirN/Alg6j"
img0000000C=STRING|"rP6b1x+MjitPnA6LjHZ2cT1UJrx0dyRXUEWLTwI9yLEJibqnemG9gp7OLSmvoBWObscCkFVgo+bXKZg"
img0000000D=STRING|"7rmyUkZoy8XhcNzXV9sUZircP2cdfKK0d1z+HDlcH0WK8fAOTGCnaycf8GlkMIz2/RBBdrAO2iyFvdT"
img0000000E=STRING|"sceubUalFfwyN3DS9mey5c9PDwpPhRK+vqnxpmIUFlQBjNPzgiLSNj8rmhXNa8DyrgFRRFWHxtTpmVB"
img0000000F=STRING|"eJx5vLYsMaW/EBn7J6aGlsyLl8ZvOnpSfb2ozY0K58YZiobVbRdCeExiewDXP3L141tJ5hZiIU1tm0d"
img00000010=STRING|"ImaWBbdClHnSZckeMvbs+ePdz/MLb77p7TX78qe2Hzv25LlBIJHHJDMj4ujZEGz69Xdpkyr7YBHKiiS"
img00000011=STRING|"yQPt8EXGw1Z2ZlSMbTUlNXVtbe/vT2/v373hRKH5B4d093ZPThjKpPI6RHhyF+sr+be3Pry/2lQgrob"
img00000012=STRING|"xDkYWj4HYxtLDsI2mpeZSV24DmK3U/m5MNISxOFuhJIfsF9/X1zs7NS5pakpksv7BY3yBaBpsTl5BID"
img00000013=STRING|"QnLLy6JLrJngfZ1uBUOMeUpxuISEkCSB0giue50c3cHAAAcHhn55d07ZfsJDpTvHRwNUKhOLq7oU0cn"
img00000014=STRING|"53y+ILl8i3UDtK95DLeRMkgxLaqqEggEVwYut7Q2tygbJfKG/sHBDx/+PtNzvlHVJm9RCWsb6ltUnWe"
img00000015=STRING|"7EumMlg5NjEC/5YK/EUMbjlgnJv/Cxe7L+iNHmrhc7uwLw9z8/NzCwuzr13+9f79oXJmemdXPvJx5Nd"
img00000016=STRING|"8/MEiLjFKqO7IaHnkidiv8ZhYRt35rXRuXL90yNDcrNCc7F41G/czM7aEh7SPd2NTkiE43pdc/m55mM"
img00000017=STRING|"pknTp0WayZsnQmBBWIsnh3LOrlWQVzWAMTYc/VHCEYOl1ef6eppUrTUyRqVqrYmpfrosZNszgFxXWOZ"
img00000018=STRING|"asiyJy4RcJtZm5YOgLgqovItMIrb7yjUndJGFNGBSqnWNKs1tXK1vLUzo0brgSzhWMtWBIDL2gZrq5W"
img00000019=STRING|"K4I646WDbq22rNfcMILTexpBwLNteaenZeG8tsuI2WeMRpgA2x/Eg60y04CyOttqUcaxVnLt/iyRmDd"
img0000001A=STRING|"el4KGE7gskdFPLhBhuxSLgcH0CgWW9hY2kTQ0YaO8LD8Kq3bIq2uNMdokjpozoDtc8Yz3bP0Smv7g="
imgcount=STRING|"27"
posx=STRING|"17"
posy=STRING|"14"
putcursor=STRING|"1"
saveresult=STRING|"0"
startx=STRING|"251"
starty=STRING|"1043"
Name=STRING|"Click left button"
action=STRING|"0"
button=STRING|"0"
EventID=STRING|"E_ONPIXELS"
UniqueID=INTEGER|-1904020894
caption=STRING|"1"
class=STRING|"0"
classexact=STRING|"0"
color0000=STRING|"$000E51D9"
comparemode=STRING|"0"
exact=STRING|"0"
findmode=STRING|"0"
pxcount=STRING|"1"
source=STRING|"1"
tolerance0000=STRING|"16"
x0000=STRING|"283"
y0000=STRING|"1057"
but no understand, where is a problem?
Send the bug-report with some message please (meny Help->Send Bug Report...)
The application retrieves the computer parameters.
Also send the screenshot of message of this task
CatID=INTEGER|1075658632
ExternalName=STRING|"Task247"
ID=INTEGER|-254603485
Name=STRING|"working set"
Name=STRING|"Show ""working set is: {WorkingSet({ProcessID})} Kb"""
msg0=STRING|"working set is: {WorkingSet({ProcessID})} Kb"
WellWisher
Product Information : RoboTask ver 7.1.0.951. Started as "User Application"
Processor Info
Manufacturer: GenuineIntel
Type: 586
Count: 8
Level: 6
Model: 60, Step: 3
Speed: 3499 MHz
Memory Info
Physical memory: 17 119 051 776
Physical memory avail: 10 988 441 600
Physical memory Load: 35%
Total virtual Memory: 34 298 920 960
Avail virtual Memory: 26 973 097 984
Virtual Memory Load: 21%
OS Info
OS version: 6.2 ()
Build: 9200
Platform: Windows NT
Disks Info
C: Fixed
Total 63 181 942 784 bytes; Free 13 944 967 168 bytes; Cluster size 4 096
D: Fixed
Total 989 582 061 568 bytes; Free 243 671 228 416 bytes; Cluster size 4 096
G: Fixed
Total 2 000 396 742 656 bytes; Free 1 184 718 483 456 bytes; Cluster size 4 096
System folders
Windows path: "C:\WINDOWS"
Program Files path: "C:\Program Files (x86)"
Temporary folder path: "C:\Users\ray~1\AppData\Local\Temp"
working set.png (4.25 KiB) Viewed 22522 times
WellWisher
Do not have any solutions?
Do you want to say that you have restarted RoboTask and it doesn't help?
Do you always get such error?
Your task looks good and it should work...
WellWisher
Every several minuts after start, Robotask is not work
We have rechecked and re-tested your task and engine of actions and Pixel Monitor trigger
No memory leaks and no leaks of other system resources. Nothing at all...
The problem somewhere else.
