CNTL key
nnman
CNTL key
Post by nnman »
I was trying to go to the last row in an Excel spreadsheet by sending the keys CNTL END. But Robotask doesn't support sending the CNTL key?
Any help is appreciated.
Thanks,
GregJ
Re: CNTL key
Hm-m...
It works. Send ^({END}) combination
also see my example below
CatID=INTEGER|1416408852
ExternalName=STRING|"Task57"
ID=INTEGER|351284147
Name=STRING|"Send CTRL+END to ""Microsoft Excel""..."
Name=STRING|"Send keys to ""Microsoft Excel"""
currentwindow=STRING|"0"
fixedwindow=STRING|"0"
keylayout=STRING|"0"
keys=STRING|"^({END})"
pause=STRING|"20"
release=STRING|"0"
sendkind=STRING|"0"
wincaption=STRING|"Microsoft Excel"
nnman
Re: CNTL key
Post by nnman »
Thanks! :)
Re: CNTL key
If you want to add some combination push the button Insert a key of the action editor (send keystrokes action) and select Key Combination item
