Hi there,
I try to install the update 7.1.1, so I downloaded close the tuning Robotask and install the update.
But, when I start Robotask the Version is 7.1.0.951?
Can anyone help me?
Try to install 7.1.1, but installed is 7.1.0.951
wwestermann
Re: Try to install 7.1.1, but installed is 7.1.0.951
7.1.1 is assembly version. Open About (Help->About) and look at the bottom-left corner.
This assembly contains corrected SSH FTP plugin
Look at system log:
I: 13.04.2018 15:23:38: **** Starting RoboTask 7.1.0.951... ************************
I: 13.04.2018 15:23:38: Application mode
I: 13.04.2018 15:23:38: Load plugins...
I: 13.04.2018 15:23:38: Plugin "General (v 7.1.0.303)" is loaded
I: 13.04.2018 15:23:38: Plugin "Dialogs and Notifications (v 7.1.0.191)" is loaded
I: 13.04.2018 15:23:38: Plugin "Files and Folders (v 7.1.0.272)" is loaded
I: 13.04.2018 15:23:38: Plugin "Zip (v 7.1.0.172)" is loaded
I: 13.04.2018 15:23:38: Plugin "Internet (v 7.1.0.219)" is loaded
I: 13.04.2018 15:23:38: Plugin "FTP Commands (v 7.1.0.167)" is loaded
I: 13.04.2018 15:23:38: Plugin "SSL FTP Commands (v 7.1.0.128)" is loaded
I: 13.04.2018 15:23:38: Plugin "SFTP (SSH FTP) (v 7.1.1.65)" is loaded
I: 13.04.2018 15:23:38: Plugin "Dial-Up (v 7.1.0.136)" is loaded
I: 13.04.2018 15:23:38: Plugin "Variables (v 7.1.0.166)" is loaded
I: 13.04.2018 15:23:38: Plugin "Task Commands (v 7.1.0.149)" is loaded
I: 13.04.2018 15:23:38: Plugin "Loops And Flows (v 7.1.0.189)" is loaded
I: 13.04.2018 15:23:38: Plugin "Window (v 7.1.0.171)" is loaded
I: 13.04.2018 15:23:38: Plugin "System Events (v 7.1.0.156)" is loaded
I: 13.04.2018 15:23:38: Plugin "System Functions (v 7.1.0.160)" is loaded
I: 13.04.2018 15:23:38: Plugin "RoboTask Commands (v 7.1.0.138)" is loaded
I: 13.04.2018 15:23:38: Plugin "Clipboard (v 7.1.0.143)" is loaded
I: 13.04.2018 15:23:38: Plugin "Mouse (v 7.1.0.144)" is loaded
I: 13.04.2018 15:23:38: Plugin "Registry (v 7.1.0.131)" is loaded
I: 13.04.2018 15:23:38: Plugin "Network (v 7.1.0.132)" is loaded
I: 13.04.2018 15:23:38: Plugin "eMail (v 7.1.0.159)" is loaded
I: 13.04.2018 15:23:39: Plugin "Strings (v 7.1.0.71)" is loaded
I: 13.04.2018 15:23:39: Plugin "Web Documents (v 7.1.0.118)" is loaded
I: 13.04.2018 15:23:39: Plugin "Regular Expressions (v 7.1.0.95)" is loaded
I: 13.04.2018 15:23:39: Plugin "ScreenShot (v 7.1.0.45)" is loaded
I: 13.04.2018 15:23:39: Plugin "XML Document (v 7.1.0.36)" is loaded
I: 13.04.2018 15:23:39: Plugin "Script Tools (v 7.1.0.42)" is loaded
I: 13.04.2018 15:23:39: Plugin "Excel (v 7.1.0.24)" is loaded
I: 13.04.2018 15:23:39: Plugin "Sound Volume (v 7.1.0.13)" is loaded
I: 13.04.2018 15:23:39: Plugin "DataBase (v 7.1.0.25)" is loaded
I: 13.04.2018 15:23:39: Plugin "Basic (v 7.1.0.175)" is loaded
Look at system log:
