Making an XML
dj.funny
Making an XML
Post by dj.funny »
dear readers,
I've a question. I'll have to make a xml form som fields off a database. For that I've used the [DEMO] Create XML library.
My only problem is that this task task a very long time to run?
When I limit the results to about 10 lines, no problem. But when I don't limit the results it are about 23,000 lines. I run the task but after 6 hours the XML isn't still ready??
Do I miss something??
Re: Making an XML
It is very difficult to say anything not without your task and your database.
How much time does this task take to make XML with 10 records?
It's necessary to see the log file. Maybe the SQL query is incorrect (or not optimized)
It can work very long time on large database. It may happened.
