Amazon AWS virtual machine, messaging limits
lsitesting2
Post by lsitesting2 »
I am currently using the evaluation version of robotask and have two questions.
- I have installed robotask on Amazon AWS virtual machine. Everything works great except the mouse recorder/macro, which I am using for some simple pointing and clicking and test input. Everything works fine when I am connected to AWS, but when I disconnect the mouse recorder/macro stops working. Is there a solution?
- I am using "Send Mail" and am occasionally now getting an error message that I have "exceeded my messaging limits". I am using SendGrid to send the emails. What is causing this error?
Thanks!
Re: Amazon AWS virtual machine, messaging limits
... but when I disconnect the mouse recorder/macro stops working...
System ignores mouse and keyboard simulation in locked (or disconnected) session. This is the property of system security.
You have to avoid any interactive actions if you want to use the task in autonomic mode.
Any public SMTP servers has some limitation of outgoing messages.
This must be in server documentation.
