this is my first post so please be gentle.
We have lots of Tasks with SFTP File Loop. Some of them are working and and the other don't find anything on the Server. All Tasks are the same (except for the servers and access data). How can i debug the Problem or get logs to analyse?
If somebody wish i can post a working and a not working Task.
Thanks in advance
SFTP File Loop Problem
Re: SFTP File Loop Problem
You can run PSFTP utility (it is in RoboTask's folder), connect to server manually and use the command "dir" or "ls"How can i debug the Problem or get logs to analyse?
The command should return the list of files and folders. Try this, please
The command "help" returns available commands with short description
on the server there lots of folders with files. The name of the folders will change every day but this is not important. I just need to make a file loop and download the files in the folders.
I run PSFTP and find all the folders and files. I can see them with filezilla too. But for Robotask it seems to me that it doesn't find any files under these folders.
If you wish i can send you the task direktly to your emailadresse. I cannot post it hear in the forum.
Yes, of course. It wold be great. My address is oleg(at)robotask.comIf you wish i can send you the task direktly to your emailadresse. I cannot post it hear in the forum.
maybe your server use some another format of directory listing. So RoboTask get some parse error and get the empty list.
Once we have corrected similar problem.
We tested sFTP action on Linux SSH, but maybe there are some different versions
tones15327
Did you ever figure out this file looping problem? I am having the same exact problem as described here.
-Filezilla works to show directory of remote SFTP files.
-Robotask can connect and download an explicit file by filename.
-Robotask file loop or SFTP Sync commands act as if there are no files in the folder and no subdirectories.
Thank you,
Tony
Thank you,
Tony
Look at my example below. It retrieves the listing of directory as text and writes listing.txt file in temporary folder-Filezilla works to show directory of remote SFTP files.
Change the login parameters and folder names for your server and run the task.
Then send file listing.txt and complete log of the to me by email for investigation
CatID=INTEGER|1604865554
ExternalName=STRING|"Task1351"
ID=INTEGER|-1271088640
Name=STRING|"Get listing command-1"
StepPause=INTEGER|0
ActionID=STRING|"A_SFTP_LOGON"
Name=STRING|"SFTP Open (<username>@localhost)"
host=STRING|"localhost"
output=STRING|"1"
password=STRING|"696917926583876828568003554383"
port=STRING|"22"
usecertificate=STRING|"0"
username=STRING|"<username>"
message=STRING|"{txt}"
Name=STRING|"Create text file {TempDir}\listing.txt"
encode=STRING|"0"
fileexists=STRING|"1"
filname=STRING|"{TempDir}\listing.txt"
line0=STRING|"*************************"
line1=STRING|"{txt}"
linecount=STRING|"2"
suppress=STRING|"0"
Name=STRING|"Show Text"
[Actions\Action12\Params]
autoclose=STRING|"0"
filename=STRING|"{TempDir}\listing.txt"
fromfile=STRING|"0"
linecount=STRING|"0"
timeout=STRING|"10"
ActionID=STRING|"A_SFTP_COMMAND"
Name=STRING|"SFTP command (dir)"
_rt_variables_produced=STRING|"txt"
command=STRING|"dir"
variable=STRING|"txt"
encode=STRING|"0"
fileexists=STRING|"0"
line0=STRING|"{txt}"
suppress=STRING|"0"
withoutprefix=STRING|"0"
Name=STRING|"SFTP command (dir test/*.zip)"
command=STRING|"dir test/*.zip"
encode=STRING|"0"
suppress=STRING|"0"
ActionID=STRING|"A_SFTP_CWD"
Name=STRING|"SFTP Change Folder (test)"
folder=STRING|"test"
