Scheduler data format inside .tsk file
george
Post by george »
Hi, I want to know in which format is the scheduler data inside the .tsk file.
For example this is a scheduler for a task set to work the 15th day of every month at 9,00am
periodicity=STRING|"2"
periodparameter=STRING|"00000000000000100000000000000000"
periodparameter2=STRING|"111111111111"
startdate=STRING|"43174"
time0=STRING|"32400000"
timecount=STRING|"1"
wakeup=STRING|"0"
Thanks
Re: Scheduler data format inside .tsk file
Why?
Do you want to change task file directly?
It doesn't make sense, because RoboTask keeps all tasks in memory when it is running.
george
Post by george »
Hi Oleg, right I want to change the task file directly.
Can you help me with this?
thanks
Below the desription
Time period.
  • 0 - every day
    1 - every week
    2 - every month
Days of the month (for time period - 2). It this case 15-th day
Months of the year. In this case - every month
Start day. The date part of standard Windows™ date-time format
The count of time list items. It this case - 1
The time item (time0, time1, time2,....,time(timecount-1) )
The time part of standard system timestamp
wakeup=STRING|"0"
Wakeup the computer
  • 0 - no
    1 - yes
But I think that this information will not help you.
Also I can repeat it again: It doesn't make sense, because RoboTask keeps all tasks in memory when it is running.
Also you can enter incorrect information and the trigger will not work at all.
Each task file contains a warning at the header: Do not edit in text editor!
The task file has text format but the format is undocumented and we can change it or add some parameters.
george
Post by george »
Thanks Oleg :D
