I've been tasked with trying to find software that will monitor a folder for new files and then copy them to a destination while preserving the folder structure.
It looks like RoboTask will absolutely be able to do this but I'm not as powerful a power user as my work seems to think and I'm having a bit of trouble.
I thought it would be a case of monitoring and then using the task in my screenshot but it doesn't seem to create the path and only sends it to the root of the drive.
Thanks in advance for any tips or sample tasks that might help.
Monitor for new file and copy with folder structure
Redintention
- Attachments
- Capture.PNG (16.4 KiB) Viewed 6887 times
Re: Monitor for new file and copy with folder structure
To copy files and preserve folder structure use Synchronize Folders action.
Copy files action only copy specified files into specified folder
