embedded browser
rgonzalez
embedded browser
Post by rgonzalez »
Hello, I have a situation with the embedded web browser with robotask 6.7.2.911 and windows xp sp3
I can access sites using TLS 1.0 but I can't access them with TLS 1.2 using the embedded web browser which I believe is because robotask uses the native iexplorer installed which in this case is IE6 and it doesn't have suppoert for 1.2
Some sites are removing support for TL 1.0 and making 1.2 the minimum and this is making some of my taks unable to complete.
Using a regular browser would make me lose some of the features of the embedded web browser.
Do you have a suggestion on how to get around this issue? Can I upgrade IE?
Re: embedded browser
Embedded web browser uses Internet Explorer system engine.
It seems you have to update IE on your computer.
