No big issue ofcourse. Low prio
[Minor bug] Escape key doesn't work
By accident, I found out that the "Escape" key to close a Window doesn't work in the "Copy/Move File" window.
- Attachments
- Screenshot of the window where the problem occurs
- Capture.PNG (14.53 KiB) Viewed 20945 times
Re: [Minor bug] Escape key doesn't work
The ESC key doesn't work if the cursor is in text editor input field.
This is standard behavior of windows elements.
You can check this on another action editor with text editor: Run program, print document, send keystrokes and so on
But I wrote this into our ToDo. Maybe this can be corrected.
Ah, makes sense. Well....in that case....good luck
