Recursive delete of some special folders
helmkehh
Post by helmkehh »
I have to delete often some folders in the Appdata of all users.
What I have is a script to delete the folders for one user.
But I didn't get it work to do the job for all users :-(
Attached you find the example I wrote.
Can anyone help me what I have to insert to do the job for all users on the machine?
Thank you!
Jan
CatID=INTEGER|0
ExternalName=STRING|"Task1"
ID=INTEGER|1071804063
LocalVariables=STRING|"FILECOUNT=,FILESIZES=,FILETODELETE="
Name=STRING|"Delete 4D AppData"
ToLog=INTEGER|2
UnicodeFormat=INTEGER|0
Action14=FOLDER
Action15=FOLDER
Action16=FOLDER
Action17=FOLDER
Action18=FOLDER
ActionID=STRING|"A_DIALOG_QUESTION"
Name=STRING|"Question Dialog"
abortif=STRING|"0"
action=STRING|"0"
autotime=STRING|"0"
buttons=STRING|"1"
message=STRING|"""Do you want to delete 4D Appdata files?"""
time=STRING|"60"
message=STRING|"Deleting empty folders"
Name=STRING|"File Loop"
[Actions\Action12\Params]
date1=STRING|"20091201"
date2=STRING|"20091201"
destvar=STRING|"C_FOLDER"
DuringMinutes=STRING|"1"
file0=STRING|"C:\Users\Jan\AppData\Roaming\4D\*.*"
file1=STRING|"C:\Users\Jan\AppData\Roaming\4D Server\*.*"
file2=STRING|"C:\Users\Jan\AppData\Local\4D\*.*"
file3=STRING|"C:\Users\Jan\AppData\Temp\4D\*.*"
file4=STRING|"C:\Users\Jan\AppData\Temp\4D Server\*.*"
filecount=STRING|"5"
searchkind=STRING|"1"
sort=STRING|"0"
sortby=STRING|"0"
sortorder=STRING|"0"
subdirs=STRING|"0"
timesize=STRING|"0"
[Actions\Action13\Params]
type=STRING|"1"
value1=STRING|"{FilesCount({c_folder})}"
value2=STRING|"0"
[Actions\Action14]
[Actions\Action14\Params]
message=STRING|"Removing {c_folder}"
[Actions\Action15]
Name=STRING|"Remove Empty Folder ({c_folder})"
[Actions\Action15\Params]
deletefolder=STRING|"0"
folder=STRING|"{c_folder}"
[Actions\Action16]
[Actions\Action17]
[Actions\Action18]
[Actions\Action18\Params]
message=STRING|"DONE. {FILECOUNT} files deleted ({FILESIZES} bytes)."
message=STRING|"*********** Start cleaning ***********"
Name=STRING|"Create variable ""FILECOUNT"" with value ""0"""
varname=STRING|"FILECOUNT"
varvalue=STRING|"0"
Name=STRING|"Create variable ""FILESIZES"" with value ""0"""
varname=STRING|"FILESIZES"
varvalue=STRING|"0"
createmode=STRING|"5"
date1=STRING|"20040614"
date2=STRING|"20040614"
destvar=STRING|"FILETODELETE"
exclude=STRING|"*.4DPreferences"
OlderDays=STRING|"7"
searchkind=STRING|"0"
sort=STRING|"0"
sortby=STRING|"0"
subdirs=STRING|"1"
timesize=STRING|"0"
Name=STRING|"Increment variable ""FILECOUNT"""
incement=STRING|"1"
vaiable=STRING|"FILECOUNT"
Name=STRING|"Increment variable ""FILESIZES"""
incement=STRING|"{FileSize({FileToDelete})}"
vaiable=STRING|"FILESIZES"
message=STRING|"Deleting file {FILETODELETE}"
Name=STRING|"Delete File"
Count=STRING|"1"
deletedirs=STRING|"1"
file0=STRING|"{FileToDelete}"
hidden=STRING|"1"
subdir=STRING|"0"
system=STRING|"1"
ToRecycleBin=STRING|"0"
UniqueID=INTEGER|-488392018
id=STRING|"UUZWQBPY"
periodicity=STRING|"0"
startdate=STRING|"4294311854"
time0=STRING|"43200000"
time1=STRING|"64800000"
timecount=STRING|"2"
Screenshot of task
Screenshot of task
