copy number from website and store it in a variable
crisp212
Post by crisp212 »
Good afternoon Oleg.
This question is a bit more complicated a think: Is it possible to copy a number in a static place in a website and pass it into a variable?
So what I want is, with a recorded action: is select a number in a fixed place in a website (drag mouse over it to select it), copy it (doing the right click and copy), pass it to a variable and then compare if its bigger or smaller than 0 or see if its negative or positive. Is it possible? The format of the number is “%xx.xx” if it’s positive and “-%xx.xx” if its negative (it can be x.xx or xx.xx really). Thank you in advance.
Regards,
Crisp212
Re: copy number from website and store it in a variable
I think that it's better to get the text from the page
Ctrl+A - select all Ctrl+C - copy to clipboard
and retrieve the value from this text by using regular expressions or some other criteria
crisp212
Post by crisp212 »
Hi Oleg!
Thanks for the fast answer.
Got it :) regex is just amazing.
Got a problem though: The task runs every 15 minutes and after the 1st run, it doesnt work :( I found out that if the % changes, it doesnt match from the "Window Caption" from the first "move object" before ctr+a/ctr+c. So if the % doesnt match, it doesnt detect the window.
Can you see another way?
Regards,
You can specify only string
/ pxzy.com - Google Chrome
and switch off the checkbox Must Match Exactly
This is a permanent part of the caption of your window.
crisp212
Post by crisp212 »
worked :) Thanks.
Regards,
