set "enabled" when windows starts or scheduled
crisp212
Post by crisp212 »
Hi Oleg!
One question:
I have a task running every second. I usually enable it manually everyday (I add a picture) Is there anyway than when I start windows, the task is set to "enabled" automatically? I seen I can make a shortcut but is only to run it once. Also I can set always "enabled" because it doesnt take much memory (5% in my case) but I wanted to know if there is another way.
Or maybe is there is a schedule option to enable it automatically the task and then disable it in a certain time.
Regards,
Re: set "enabled" when windows starts or scheduled
Look at the Enable Task and Disable Task actions
You can make another task which enables or disables certain task by scheduler or other criteria.
crisp212
Post by crisp212 »
Thanks Oleg! Worked fine :)
Regards,
