If specific color excist > do this - If not > skip
snowseals
Post by snowseals »
Happy new year Oleg!
I'm trying to figure out , How to move to object + click and & delay - ONLY if specific color excists.
If not, skip (and just continue).
So far I've tried using Color Compliance and If Then / Else Then, but I cant seem to get it working.
Basically, it boils down to this:
Depending on the input of data, a website pops up a blue-button somewhere on the screen, or not.
The times it doesnt pop up it should skip the handling afterwards (to click this button and continue)
The times it does pop up it should click this button and continue.
See also: https://youtu.be/K7e_MvQX-sM
How to create such script?
Re: If specific color excist > do this - If not > skip
You have to get the pixel from necessary place of the screen (not window use full screen)
Make comparison with Color compliance action. This action save TRUE or FALSE into your variable
Next, use If..Then action
snowseals
Post by snowseals »
Like this?
CatID=INTEGER|0
ExternalName=STRING|"Task1111"
ID=INTEGER|1830696294
Name=STRING|"If color = blue do this, else do that"
UnicodeFormat=INTEGER|0
Name=STRING|"Create local variable ""COLORMATCHED"" with value ""false"""
varname=STRING|"COLORMATCHED"
varvalue=STRING|"false"
ActionID=STRING|"A_SCR_SCRPIXEL"
Name=STRING|"Screen Pixel"
variable=STRING|"color"
x=STRING|"668"
y=STRING|"585"
ActionID=STRING|"A_SCR_COLORCOMPLIANCE"
Name=STRING|"Color Compliance"
color1=STRING|"{color}"
color2=STRING|"$00DD8833"
tolerance=STRING|"5"
variable=STRING|"ColorMatched"
Name=STRING|"Delay 1 sec"
delay=STRING|"1"
dimension=STRING|"1"
operator=STRING|"1"
value1=STRING|"{ColorMatched}"
Name=STRING|"Show ""Point color is not blue."""
msg0=STRING|"Point color is not blue."
ActionID=STRING|"A_FLOW_ELSE"
Name=STRING|"Else"
Name=STRING|"Show ""Point color is blue!"""
msg0=STRING|"Point color is blue!"
Yes. It seems the algorithm of your example is correct.
But I think that step #4 (Delay 1 sec) has no sense.
snowseals
Post by snowseals »
I'll try in a bit implementing this in excisting script.
I put that Delay 1 sec in it, since it's not instantly showing that pop-up/blue button after u press a button (that will either show or not show the pop-up popping) ;)
Hence I believe I need to use the Delay, otherwise, it will right away tell me there's no such blue pixel.
In this case you have to put delay before screen pixel action
The delay has no sense if you already get the color from screen.
snowseals
Post by snowseals »
Yep, u right! Thanks :)
Script = working like this now:
CatID=INTEGER|0
Name=STRING|"If color = blue do this, else do that (imported)"
Action14=FOLDER
Name=STRING|"Click button"
action=STRING|"0"
button=STRING|"0"
Name=STRING|"//End of MacroRecoder block"
comment=STRING|"End of MacroRecoder block"
Enabled=INTEGER|0
[Actions\Action12\Params]
ActionID=STRING|"A_SCR_WAITFORPIXELS"
Name=STRING|"Wait for Pixels (full screen)"
[Actions\Action13\Params]
caption=STRING|"1"
class=STRING|"0"
classexact=STRING|"0"
color0000=STRING|"$00EDF1F2"
comparemode=STRING|"0"
exact=STRING|"0"
findmode=STRING|"0"
infinity=STRING|"0"
pxcount=STRING|"1"
source=STRING|"1"
timeout=STRING|"60"
tolerance0000=STRING|"16"
x0000=STRING|"904"
y0000=STRING|"695"
[Actions\Action14]
x=STRING|"906"
y=STRING|"695"
operator=STRING|"1"
Enabled=INTEGER|0
Name=STRING|"Break"
Name=STRING|"Else"
Name=STRING|"//Begin of MacroRecoder block"
comment=STRING|"Begin of MacroRecoder block"
ActionID=STRING|"A_MOUSE_MOVETO"
Name=STRING|"Move To Object"
bottom=STRING|"1040"
controlclass=STRING|"Chrome_RenderWidgetHostHWND"
controltext=STRING|"Chrome Legacy Window"
ctrltextexact=STRING|"1"
left=STRING|"0"
right=STRING|"1920"
top=STRING|"130"
windowclass=STRING|"Chrome_WidgetWin_1"
windowtext=STRING|"AutotelexPRO - Google Chrome"
wintextexact=STRING|"0"
x=STRING|"910"
y=STRING|"562"
