deesloop
Posts: 70 Joined: Wed Feb 25, 2009 3:44 am
Post
by deesloop » Tue Dec 19, 2017 11:58 am
Is it possible to perform calculations on variables other than increment.
I'd like to subtract one variable from another, but it'snot working with set variable
[Actions\Action19]
Name=STRING|"Get number imported"
[Actions\Action19\Params]
varname=STRING|"NUMIMPORTED"
varvalue=STRING|"{COUNTAFTER}-{COUNTBEFORE}"
Posts: 3284 Joined: Thu Jan 01, 1970 1:00 am
Post
by Oleg » Tue Dec 19, 2017 1:32 pm
If you need to make some calculations you have to use
VB Evaluate or
JS Evaluate actions
Set variable only sets the variable with specified string and expands variables in the text
Look at the example below. Save the text of the task to a file and use menu Task->Import to import the task into RoboTask.
ExternalName=STRING|"Task294"
ID=INTEGER|73528162
Name=STRING|"calculate the expression"
Name=STRING|"Set variable ""COUNTAFTER"" with value ""26"""
varname=STRING|"COUNTAFTER"
varvalue=STRING|"26"
Name=STRING|"Set variable ""COUNTBEFORE"" with value ""10"""
varname=STRING|"COUNTBEFORE"
varvalue=STRING|"10"
Name=STRING|"VB Evaluate"
expression=STRING|"{COUNTAFTER}-{COUNTBEFORE}"
linecount=STRING|"0"
loadfromfile=STRING|"1"
variable=STRING|"res"
Name=STRING|"Show ""{COUNTAFTER}-{COUNTBEFORE} = {res}"""
msg0=STRING|"{COUNTAFTER}-{COUNTBEFORE} = {res}"
deesloop
Post
by deesloop » Tue Dec 19, 2017 3:25 pm
Great, that's exactly what's needed
