Set scheduler/cyclic
crisp212
Post by crisp212 »
Hi Oleg.
One more question :)
So I want to run my task from 19:05 to 19:15h every day. When the task runs, it cycles every 1s.
The 1 second cycle: no problem. Add cyclic in the triggering Events.
Running from 19:05h from 19:15h. Added the Scheduler to run every day. Then with the wizard, Start time 19:05:00 End time 19:15:00 Step (min) 1 How much 10
Click ok. Then I enable the task at 19:01 but it runs any way instead of running at 19:05.
What I am doing wrong?
Regards and thank you,
D.
Re: Set scheduler/cyclic
Look at my example below.
This task started every 2 seconds BUT it perform your necessary steps only from 19:05 up to 19:15
You can use if..then action to make any condition for your actions
ExternalName=STRING|"Task285"
ID=INTEGER|1386272400
Name=STRING|"from 19:05 up to 19:15"
case#1=STRING|"0"
count=STRING|"2"
operator=STRING|"2"
operator#1=STRING|"4"
type=STRING|"2"
type#1=STRING|"0"
value1=STRING|"{Time}"
value1#1=STRING|"{Time}"
value2=STRING|"19:05"
value2#1=STRING|"19:15"
Name=STRING|"//do something"
comment=STRING|"do something"
Name=STRING|"//put here your steps"
comment=STRING|"put here your steps"
UniqueID=INTEGER|-1875291276
interval=STRING|"2"
