Mail loop with last X mails
marcolobaido
Post by marcolobaido »
Hi, I need to do a mail loop downloading mail with a specific word in the subject.
I made a task that works perfectly but it's too slow because it analyzes ALL the mails.
I tried to use a "while loop" and "imap folder info" but it's slow too because I must download every single mail to get the subject differently to the "imap mail loop" action.
Is there a way to analyze only the last 100 mails with imap mail loop?
Re: Mail loop with last X mails
You have to use some counter in the mail loop.
Process messages from 1 to 100. Next you can break the loop. Use Break action
Algorithm will be similar to this:
IMAP open
IMAP Mail Loop // set ordering number to NUM
   do something
   if {num} >100 then
      break
   end if
End loop
So, if mail box contains less than 100 massages you process all messages. If more than 100 you process only 100 newest messages.
marcolobaido
Thanks for you very fast answer,
I have 2178 mails and I need to process messages from 2078 to 2178.
I set the ordering number with the value (num = 2078) breaking when num>100 but it start always from the oldest mail.
imap open
imap folder info
increment variable (2 variables: total mail {nums} and total -100 {num})
imap mail loop (ordering number {num})
if {num}>100
break
if subject contain word
download message
end if
end loop.
What's wrong? :roll:
I'm sorry, you are correct: newest messages are at the end of the list
look at my example below how to read only 100 last messages
CatID=INTEGER|1539658767
ExternalName=STRING|"Task272"
ID=INTEGER|1723780338
Name=STRING|"check only last 100 emails"
ToLog=INTEGER|2
Action14=FOLDER
Action15=FOLDER
message=STRING|"*****************"
ActionID=STRING|"A_IMAP_DOWNLOAD"
Name=STRING|"IMAP Download Message"
extract=STRING|"0"
num=STRING|"{num}"
overwrite=STRING|"1"
savefilenames=STRING|"0"
savetofile=STRING|"{TempDir}\tmp.eml"
ActionID=STRING|"A_EMAILE_PARSE"
Name=STRING|"Parse Email Message"
cc=STRING|"0"
date=STRING|"1"
datevar=STRING|"dt"
extract=STRING|"0"
file=STRING|"{TempDir}\tmp.emp"
from=STRING|"0"
overwrite=STRING|"0"
priority=STRING|"0"
subj=STRING|"1"
subjvar=STRING|"subj"
text=STRING|"0"
texttype=STRING|"0"
to=STRING|"0"
[Actions\Action12\Params]
message=STRING|"{num}: {subj}"
[Actions\Action13\Params]
message=STRING|"{num}: {dt}"
[Actions\Action14]
Name=STRING|"Break"
[Actions\Action15]
ActionID=STRING|"A_IMAP_OPEN"
Name=STRING|"IMAP Open"
folder=STRING|"INBOX"
host=STRING|"imap.gmail.com"
password=STRING|"46697457712734240652452634424341422"
passwordmode=STRING|"1"
port=STRING|"993"
SSL=STRING|"1"
user=STRING|"your-user-name"
ActionID=STRING|"A_IMAP_MSGCOUNT"
Name=STRING|"IMAP Folder Info"
folder=STRING|"0"
recent=STRING|"0"
total=STRING|"1"
unseen=STRING|"0"
vartotal=STRING|"sz"
Name=STRING|"VB Evaluate"
expression=STRING|"{sz}-100+1"
linecount=STRING|"0"
loadfromfile=STRING|"1"
variable=STRING|"delta"
operator=STRING|"4"
type=STRING|"1"
value1=STRING|"{delta}"
value2=STRING|"0"
Name=STRING|"Set variable ""DELTA"" with value ""1"""
varname=STRING|"DELTA"
varvalue=STRING|"1"
message=STRING|"delta = {delta}"
Name=STRING|"Simple Loop"
begin=STRING|"{delta}"
end=STRING|"{sz}"
variable=STRING|"NUM"
You can change the amount of the messages, look at the step #4
marcolobaido
ok, It works. Thank you very much.
P.s.
I noticed that simple loop is slower than mail loop, this is my impression (can you confirm that?).
However I think that would be useful to add a Mail loop action where I can choose to start from the newest or last mail.
This task downloads the whole message, but Email loop reads only message headers if it's necessary.
Therefore you see that simple loop works a bit slower.
Maybe we will improve email loop actions (IMAP and POP3) in order to avoid such complex construction
I wrote the request into our ToDo.
