crisp212
Posts: 21 Joined: Mon Dec 04, 2017 7:12 pm
Post
by crisp212 » Wed Dec 13, 2017 5:09 pm
Good afternoon Oleg.
First of all, thanks for answering previous questions. I am getting there to what I want
One question: How do I trigger a message/prompt at 00s from the next minute? For example (using previous question about alerts in cities):
So I receive an email with subject “Alert in Chicago” at 17:03:30. I want that the prompt window or message comes out at 17:04:00 exactly and not the moment the loop finds the text (for example at 17:03:32). Is it possible?
Trying a while loop with Date and time where first operand is {Seconds} and second is 00 but if gives me error.
Regards and thank you for your time.
Dan
Posts: 3310 Joined: Thu Jan 01, 1970 1:00 am
Post
by Oleg » Thu Dec 14, 2017 1:10 pm
Look at the example below.
It waits when variable
seconds will equal to 0. The task checks the variable in the loop
CatID=INTEGER|1823304062
ExternalName=STRING|"Task257"
ID=INTEGER|-1540514227
Name=STRING|"At 1-st secont on next minute"
Name=STRING|"While loop"
operator=STRING|"1"
type=STRING|"1"
value1=STRING|"{Seconds}"
value2=STRING|"0"
Name=STRING|"Delay 100 ms"
delay=STRING|"100"
dimension=STRING|"0"
Name=STRING|"Show ""[{Time}.{mSeconds}, {DayOfWeek}, {Date}]"""
msg0=STRING|"[{Time}.{mSeconds}, {DayOfWeek}, {Date}]"
msg1=STRING|"Hey, awake!"
msgcount=STRING|"2"
crisp212
Post
by crisp212 » Fri Dec 15, 2017 11:58 pm
Worked
Thanks Oleg.
