take random word from many words in subject of email
crisp212
Post by crisp212 »
Good morning Oleg.
Still trying your software and is amazing what it can do. I am trying this now and need help:
I want that when I receive a mail with the subject “Alert in xxxx/xxxx”, “ xxxx/xxxx” show it on screen.
So for example, Receive an email with “Alert in Miami/Florida” or "Alert in Sacramento/California" or other random city, then pop ups a screen with “Miami/Florida is having problems” or "Sacramento/California is having problems". xxx is a random incoming string but always after "Alert in"
I got all the email correctly (IMAP, etc.) but I don’t know how to take the "xxx" to variable automatically.
Regards,
D.
Re: take random word from many words in subject of email
I think you have to use regular expressions.
Look at my example below.
ExternalName=STRING|"Task3"
ID=INTEGER|14240530
Name=STRING|"Random word"
Name=STRING|"Create local variable ""LIST"" with value ""Alert in Chicago{EOL}Some other string{EOL}Alert in Houston{EOL}Alert in New York{EOL}alert in Los Angeles """
varname=STRING|"LIST"
varvalue=STRING|"Alert in Chicago{EOL}Some other string{EOL}Alert in Houston{EOL}Alert in New York{EOL}alert in Los Angeles "
Name=STRING|"Text Loop"
destvar=STRING|"LINE"
line0=STRING|"{list}"
sourcetext=STRING|"1"
Name=STRING|"RegExp Match"
anchored=STRING|"0"
case=STRING|"1"
extended=STRING|"0"
line00000000=STRING|"{Line}"
multiline=STRING|"0"
noautocapture=STRING|"0"
pattern=STRING|"Alert in (.+)$"
savesubexpression=STRING|"1"
singleline=STRING|"0"
subexpressionpos=STRING|"0"
ungreedy=STRING|"0"
useexternal=STRING|"0"
variable=STRING|"match"
value1=STRING|"{match}"
Name=STRING|"Show ""Sourse line: {Line}"""
msg0=STRING|"Sourse line: {Line}"
msg1=STRING|"Composed line: {expr(1)} is having problems"
msgcount=STRING|"2"
ActionID=STRING|"A_FLOW_ELSE"
Name=STRING|"Else"
Name=STRING|"Show ""{Line}"""
icon=STRING|"0"
msg0=STRING|"{Line}"
msg1=STRING|"***************"
msg2=STRING|"Expression is not matched"
msgcount=STRING|"3"
