ExtractFileNameNoExt multiline variable
marcolobaido
Post by marcolobaido »
Hi, I assigned several paths to a variable {A} and so It's a multiline variable. I need to write a file list without extention. ExtractFileNameNoExt{A} doesn't work.
what's the simplest way to use ExtractFileNameNoExt function with multiline variables?
Is there a simpler way than using text loop with variable {A}?
Re: ExtractFileNameNoExt multiline variable
If you have a list of files as a text (one file name per line) you have to use Text Loop action and extract names line-by-line
You can't extract file name from the list.
also look at my example how to do this (see below)
ExternalName=STRING|"Task103"
ID=INTEGER|246339309
Name=STRING|"Get filename from file list"
Name=STRING|"Create local variable ""LIST"" with FileNames"
varname=STRING|"LIST"
varvalue=STRING|"D:\Temp\example.docx{EOL}D:\Temp\error.png{EOL}D:\Temp\test.xls{EOL}D:\Temp\download.xml"
Name=STRING|"Text Loop"
destvar=STRING|"NAME"
line0=STRING|"{List}"
sourcetext=STRING|"1"
Name=STRING|"Show ""Full name:"""
msg0=STRING|"Full name:"
msg1=STRING|"{Name}"
msg3=STRING|"Name only:"
msg4=STRING|"{ExtractFileNameNoExt({Name})}"
msgcount=STRING|"5"
