Posts: 237 Joined: Mon Feb 22, 2016 4:06 pm
Post
by Rukbunker » Thu Nov 09, 2017 1:42 pm
Hey Oleg,
After a "Create File List" function, 1 filename is saved into the variable {FILE}. This is good and how it should be. It's a ZIP file, but the name differs every time. After that, I want to extract that ZIP file.
When I use the "Extract Files" function with {FILE}, an error occurs with no reason. When I use the full patch (EXACTLY the same as in the variable) it works perfectly. How come that this function doesn't accepts variables?
upload pic
Posts: 3304 Joined: Thu Jan 01, 1970 1:00 am
Post
by Oleg » Thu Nov 09, 2017 2:27 pm
I wrote a little example (see below)
It works
CatID=INTEGER|1075658632
ExternalName=STRING|"Task331"
ID=INTEGER|-248401785
Name=STRING|"extract files (name in variable)"
Name=STRING|"Create local variable ""FILE"" with value ""D:\Temp\zip\bin.zip"""
varname=STRING|"FILE"
varvalue=STRING|"D:\Temp\zip\bin.zip"
Name=STRING|"Create local variable ""FOLDER"" with value ""{ExtractFilePath({File})}"""
varname=STRING|"FOLDER"
varvalue=STRING|"{ExtractFilePath({File})}"
ActionID=STRING|"A_ZIP_EXTRACT"
Name=STRING|"Extract Files"
destdir=STRING|"{folder}"
filetounzip=STRING|"{File}"
overwrite=STRING|"0"
password=STRING|"2693725194264782545612397"
passwordmode=STRING|"0"
skipolderfiles=STRING|"0"
usefoldernames=STRING|"1"
Maybe the problem somewhere else.
Are you sure that variable contains correct name?
Post
by Rukbunker » Tue Nov 21, 2017 1:26 pm
I have imported your task. The value of the variable is being saved correctly, but as said: unzipping with the usage of {MyVar} is not working. The full path works. See for yourself:
Post
by Oleg » Tue Nov 21, 2017 2:54 pm
Could you send your task to me?
It seems the problem is in the task. I don't see your example, only some screenshots
