How to count running robotask.exe processes
Shawnturner
Post by Shawnturner »
Hello Everyone,
we got some trouble after robotask.exe was running parallel in three different processes on one VM. All the scheduled processes run threetimes, filled up database tables with same data etc..
I don't know how we could came into this situation.
How can I set up a task for counting the number of currently running processes of robotask.exe?
OS: Windows 2008 R2 Standard, SP1
Robotask: 6.2.0.859
Any Idea , Suggestions would be appreciated,
Thanks,
I didn't find the right solution.
Re: How to count running robotask.exe processes
You can use TASKLIST.EXE system utility to enumerate processes
also look at the task below how to count ROBOTASK processes in the system.
RoboTask can be running only once within user session. You can get many images if you have many user sessions on your server (for example RDC sessions)
I have only two images of RoboTask.EXE process: from my user session and system service
CatID=INTEGER|1360203151
ExternalName=STRING|"Task154"
ID=INTEGER|-2060590109
Name=STRING|"count RoboTask processes"
ActionID=STRING|"A_MISC_RUNCONSOLEAPP"
Name=STRING|"Run command-line utility: tasklist /FI ""IMAGENAME eq robotask.exe"" /nh"
convertansi=STRING|"1"
ifnonzero=STRING|"0"
outputvar=STRING|"out"
params=STRING|"/FI ""IMAGENAME eq robotask.exe"" /nh"
program=STRING|"tasklist"
saveexitcode=STRING|"0"
saveoutput=STRING|"1"
ActionID=STRING|"A_STR_TRIM"
Name=STRING|"STR Trim"
custom=STRING|"0"
eol=STRING|"1"
lead=STRING|"1"
source=STRING|"{out}"
spaces=STRING|"1"
tabs=STRING|"1"
trailing=STRING|"1"
variable=STRING|"out"
ActionID=STRING|"A_TXT_NUMBEROFLINES"
Name=STRING|"TXT Number of Lines"
external=STRING|"0"
line00000000=STRING|"{out}"
variable=STRING|"num"
Name=STRING|"Show ""RoboTask is running {num} time(s)"""
msg0=STRING|"RoboTask is running {num} time(s)"
msg1=STRING|"********************"
msg2=STRING|"{out}"
msgcount=STRING|"3"
